LSJ intake manifold removal??
Old Apr 24, 2014 | 10:00 PM
gbpackrfan04's Avatar
I know there are already threads about this but I still can't seem to get it off. I currently have the 5 on the top removed and the 15mm one on the passenger side removed (removed alternator). I know I gotta be missing something!!
Any help would be appreciated!!
Old Apr 24, 2014 | 11:22 PM
double clutch's Avatar
Theres 5 nuts on top and 1 bolt behind the manifold. Thats it. Should pull right off the studs
Old Apr 24, 2014 | 11:30 PM
ItalianJoe1's Avatar
Try removing the studs if you haven't already. If you took the bottom bolt out the manifold should be quite loose, and should just pull straight up. What/where does it seem to be stuck on?
Old Apr 24, 2014 | 11:37 PM
It just seems stuck and does not want to budge at all. I can't seem to get any portion of the manifold to even come slightly loose. I've tried tapping it with a rubber mallet but maybe I just need some more umph to break the seal?
Old Apr 24, 2014 | 11:39 PM
Try to pry it off the block, it must be just stuck on there.
Old Apr 24, 2014 | 11:43 PM
Yeah I will try that tomorrow. Didn't wanna start prying at it if it was still connected somewhere lol. I will give an update tomorrow. Thanks for the help
Old Apr 25, 2014 | 04:04 AM
Speedytec's Avatar
Ehhhh 5??
There are 7 bolts/nuts that hold the intake manifold to the head (5 short, 2 long studs) and that 15mm bolt on the lower bracket.
Old Apr 25, 2014 | 06:56 AM
sLAsh's Avatar
Like Speedyteec said you missed some. You got the elusive one that people usually miss(#907 in the diagram) but are missing a couple where the intake connects to the head.
Look here
LSJ.jpg Photo by balmung92003 | Photobucket
and here
Last edited by sLAsh; Apr 25, 2014 at 07:11 AM. Reason: Cant get the photobucket image link to work but here is the URL
Old Apr 25, 2014 | 09:08 AM
I havent taken mine off in awhile. I thought there was only 5 on top. Sorry for misinformation
Old Apr 25, 2014 | 02:46 PM
Thanks guys, I got it off. It is a lot easier to find when its not covered up with tape. LOL
DarrenGC
Dec 24, 2021 01:55 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
