LSJ Throttle Hesitation
Old Apr 27, 2014 | 08:58 PM
guess1's Avatar
I have a problem that has plagued my car for a while, it is intermittent, doesn't do it every day of the week.
When driving my car, once it is properly warmed up, and I'm cruising for example at 2500 rpm's in 2nd gear (lets say 1/4 gas? idk 1/8 maybe). If i try to speed up quickly, say 1/2 or 3/4 gas, i get no power for a couple of seconds, and then my car lurches forward with a surge of power.
Happens more frequently after a full throttle run that leads into cruising at a set speed, but not always, can happen simply driving around town with no hard runs.
Modifications That could relate to this issue:
- 1 Step colder NGK Coppers (Changed multiple times since this started, also tried stock heat range)
- e85 Tune (Dyno Tune done @ ZZP in Michigan)
-Smaller pully (i think 2.7?)
-ZZP Cat Back
-ZZP Downpipe w/high-flow cat
-80# Injectors
-New Fuel Filter
Any help is appreciated, thank you!
Old Apr 29, 2014 | 07:58 PM
Unicorn's Avatar
Possibly the air-flow censor? Had that problem on a Malibu and it got to the point where my car hesitated to get up hills. But it would mostly do it on hills..
Misfire?
Injectors? Have you had those checked?
Old Apr 29, 2014 | 08:16 PM
yellowsupercharged06's Avatar
We got the same mods lol
I would suggest the maf as well, mine went bad and fuked up my hole tune cuz we didnt knw at the time and tuned on a bad maf ... But ya it might be ur maf .. Mite need a retune after u replace it tho
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Oct 13, 2015 09:32 PM
717ssbalt
Oct 2, 2015 04:01 PM
