lsj timing chain guides
Old May 3, 2021 | 10:56 PM
primem's Avatar
I have a stock 07 lsj with 155 000 kilometers.
How do the timing chain fixed, adjustable and upper guides hold up. I realize there is no maintenance interval but its plastic so do i need to worry about it. I am not having any drivability problems or cam crank correlation dtc.
Old May 5, 2021 | 08:33 AM
Tdubbs's Avatar
Always replace them. The entire kit is cheap enough that it's not worth trying to skip them. If they do go, and it's common enough, motor go boom.
Old May 5, 2021 | 03:11 PM
primem's Avatar
i'm trying to determine an interval for replacement: I have no data on when they have failed for others.
Old May 5, 2021 | 03:20 PM
Tdubbs's Avatar
Although you could stretch longer, general consensus is every 100,000mi. Some have failed before and some never, a lot of variables to account for.
Old May 5, 2021 | 05:26 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Depends on a thousand factors. I've always generally seen 100,000 miles (~160,000 km) as a general recommendation.
My timing chain tensioner started to fail around 70,000 miles, iirc.
Old May 5, 2021 | 07:08 PM
ProfDNS's Avatar
Replacing mine next week. 185,000km, or roughly 115,000 miles. There's definitely signs of slack that I hear.
Medida
May 11, 2018 10:35 AM
LTBALTBMX
Jul 4, 2016 12:33 AM
ford
Jan 30, 2013 03:48 PM
tomj77
May 13, 2012 05:23 PM
harryresh
May 13, 2010 04:29 PM
