MAF Help
Old Jan 31, 2012 | 08:45 AM
erockxp's Avatar
MAF Help
So I went to remove my MAF to clean it and the screws are seized up. I have a full set of torx bits and am sure that none of them will fit. Any ideas? Help!
Old Jan 31, 2012 | 12:41 PM
06cobalt racer's Avatar
small amount of pb blaster should work. mine are regular screws not torx's
Old Jan 31, 2012 | 06:40 PM
Coblasts's Avatar
If the torx gets stripped remove the intake ,but if you can get a hand drill in there drill off the heads of the screws( the torx hole will keep the drill centered).
Use a bit bigger than the threaded part would be but smaller than the screw head.
Once the heads pop of remove the maf and use a vise grip on the studs that are left to unscrew them.
Apply wd 40 or some kind of loosened on the studs to help removal .
Old Feb 1, 2012 | 03:50 PM
erockxp's Avatar
Thanks for the help. I am a bit nervous about drilling those screws out and may just leave it be for time being. I appreciate the detailed responses.
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
Superslowbaltt
Sep 22, 2015 10:24 AM
Superslowbaltt
Sep 21, 2015 07:50 PM
