Major misfiring issue
Old Feb 23, 2010 | 01:14 AM
jimbos'ss's Avatar
Originally Posted by cobalttech
i have an 2006 LS trim and i did check for vacuum leaks and only found one which was my fault as i forgot to put the hose clamp back on the leads from the air intake to the cylinder head. Other than that my dad and i checked all over the engine and couldnt find leaks anywhere else. we also checked the relay for the SAI pump and found that it was working correctly. im thinking at this point that the MAF sensor is somehow not sending a signal to the SAI pump on when to open and close the valve on it and it causing the exhaust to leak out into the SAI pump line. as for not being able to rev past 4k now i can definitely attribute that to the MAF sensor from what i know about that causing issues with revving.
never worked with the SAI system, but it does sound like it may definately be the maf sensor. lotta cobalt owners in california though, might be able to get someone to lend you there maf sensor for a few minutes to see if it fixes your problem. also check the maf sensor voltage, should be 0-5v.
Old Feb 24, 2010 | 11:02 AM
BULLETSSMOKE's Avatar
Originally Posted by jimbos'ss
check the fuel system.
There was a recall on Cobalts for the fuel pump, some cobalts have this problem, some dont. Go ask them.
Old Feb 24, 2010 | 12:05 PM
jimbos'ss's Avatar
that was for leaking fuel pump canisters, another common fuel problem is also the evap canister.
Old Feb 24, 2010 | 03:06 PM
cobalttech's Avatar
yeah as i think i mentioned in my OP i had that exact recall done on my cobalt as it was leaking fuel from the canister, but they did replace it already along with installing a new fuel filter. gonna be making a visit to fonzi this weekend to pick up his MAF, SAI pump and DP this weekend so we'll see how it goes and i'll post back with the results.
Old Feb 24, 2010 | 03:55 PM
Fonzi1289's Avatar
Yeah man hopefully my parts help
Old Mar 1, 2010 | 10:21 AM
cobalttech's Avatar
hey all, just reporting back to you guys with my results like i said i would. well after throwing on 2 out of 3 of the parts that fonzi sold to me the last one seemed to do just what i was hoping it would and low and behold it was the DP with the cats on it that was causing the issue. Cobalt is back to normal and actually is running even better than before anything went wrong with it, alot more responsive and feels like i may have picked up a few extra HP anyway many thanks go out to fonzi for all the parts that he sold to me and hopefully by the time the next meet comes up i'll be able to be finished with my body kit and have her ready to show off to you guys again thanks everyone for all the input i'll never forget it.
Old Mar 1, 2010 | 10:30 AM
sundevil07's Avatar
it was the cat? what the hell lol, well glad you got it fixed!
Old Mar 1, 2010 | 02:06 PM
jimbos'ss's Avatar
check the catalytic converter
so it was the cat huh lol
Old Mar 1, 2010 | 02:32 PM
cobalttech's Avatar
yeah it was, just kinda weird though cause when i checked out the cat myself along with my dad it didnt look like it had any blockage going on, but as fonzi suggested to me when i talked to him in person it may have been a partial clog.
717ssbalt
Oct 2, 2015 04:01 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
