Map sensor plug n play help!
Old Nov 19, 2016 | 06:49 PM
redman2357's Avatar
Hey guys. Might be a dumb question but how do I install new harness to map sensors? I see where it snaps to map sensor itself but where does the other end go to? Thanks
Old Nov 19, 2016 | 07:36 PM
Tdubbs's Avatar
If you are referring to the 3bar map kit, the one end plugs into the map sensor and the other end plugs into the connector from the vehicle harness that used to plug into the map. The one with 4 wires goes to the one in the charge pipe and the one with 3 goes to the manifold one.
Old Nov 19, 2016 | 07:55 PM
redman2357's Avatar
I tried that and it's not fully connecting to it???
Old Nov 19, 2016 | 08:31 PM
Tdubbs's Avatar
Who did you get the harnesses from? When I got mine from CED they just plugged right in and clicked, although they were a little stiff(the seals). You could try to use a bit of dielectric grease to lube the rubber so it slides in easier.
Old Nov 19, 2016 | 08:47 PM
redman2357's Avatar
Yes I bought them from CED also. It barley meets where it clicks together. Does there have to be a retune on them also?
Old Nov 19, 2016 | 08:50 PM
Tdubbs's Avatar
No retune required for just the harness, but I would check your other thread for info I posted for you.
Old Nov 19, 2016 | 10:21 PM
63 Nova SS's Avatar
If you purchased the non solder ones they should work and go together. They fit pretty tight so they don't get moisture in them.
