Map sensor plug n play help!
Hey guys. Might be a dumb question but how do I install new harness to map sensors? I see where it snaps to map sensor itself but where does the other end go to? Thanks
If you are referring to the 3bar map kit, the one end plugs into the map sensor and the other end plugs into the connector from the vehicle harness that used to plug into the map. The one with 4 wires goes to the one in the charge pipe and the one with 3 goes to the manifold one.
Who did you get the harnesses from? When I got mine from CED they just plugged right in and clicked, although they were a little stiff(the seals). You could try to use a bit of dielectric grease to lube the rubber so it slides in easier.
Yes I bought them from CED also. It barley meets where it clicks together. Does there have to be a retune on them also?
