Misfire at high rpms , under load , boost cut @ 5psi (lsj)
Old 01-09-2018, 11:30 PM
nismoskyline350's Avatar
So my car started having this issue (lsj sc) where under load after 5psi the car would missfire , ive replaced plugs, gapped em at .035 , changed the evap unit that tends to mess up the idle on these cars, new /upgraded coils, only thing i havent replaced are the 02 sensors , the fuel pump was replaced aswell , any ideas guys?
Old 01-10-2018, 07:49 AM
jdbaugh1's Avatar
Are you tuned or throwing any codes? Do you have a wideband gauge?
Old 03-23-2018, 06:37 PM
im not tuned and i get a random check engine light that comes and goes , im not sure what a wideband gauge is, i just cleaned out the air filter and maf, aswell as changed the 02 sensors i still have the same issue
Old 03-23-2018, 06:39 PM
another thing when i do have a check engine light when i hook up the scanner it wont even read or turn on to read the codes ive tried multiple scanners when i do have the light on and none of them even read the cars codes
Old 03-23-2018, 07:10 PM
cluelessk's Avatar
Are you using just a generic OBD2 scanner?
Try getting a higher end scanner on it. Even though it sucks it might be worth paying a shop.
I'm not sure if LSJ's are as picky as the LNF but for the LNF OEM spark plugs are recommended.
Also what do you mean by "upgraded" coils? OEM is more than enough for you and usually more reliable by a large margin over aftermarket.
Aftermarket replacement parts are quite often trash. Especially when it comes to sensors and electronics.
Old 03-23-2018, 07:53 PM
they are np boosted coils theyre red ones and yes a couple different generic scanners
Old 03-23-2018, 08:19 PM
cluelessk's Avatar
I'd find Oem coils asap. Even used.
Pretty much anything is better than EBay specials.
sixgear
09-14-2021 02:24 PM
AZCobaltss
10-29-2014 03:02 PM
blake05SS
03-15-2011 05:16 PM
InfraRedline
10-07-2009 02:31 PM
Jmc007
Tuning
18
07-24-2007 08:22 PM
Quick Reply: Misfire at high rpms , under load , boost cut @ 5psi (lsj)
