Misfire Problem
Old Jun 21, 2007 | 01:39 AM
ikeryder13's Avatar
Misfire Problem
My check engine light has come on and i just wanted to know i took my car and found out the problem was a misfire in random to multiple cyllinders.... What could cause this to happen and what can i do to correct this problem...
Old Jun 21, 2007 | 01:40 AM
shaunmcdee's Avatar
You can try first changing your plugs.
Old Jun 21, 2007 | 01:42 AM
ikeryder13's Avatar
should i just take it do the dealer ship i have full warranty or is this not covered?
Old Jun 21, 2007 | 01:45 AM
shaunmcdee's Avatar
Should be covered, it still has the power train warranty that all 07s come with, so heck ya, i just got my car out of the dealershi today actually.
what part of railto, i just moved from there, Lilac and jackson, right by ike high
Old Jun 21, 2007 | 01:46 AM
ikeryder13's Avatar
would it cause my car not to idle right?
Old Jun 21, 2007 | 01:48 AM
shaunmcdee's Avatar
Well alot of things would make your car not idle right, plugs would be one of them.
Whats wrong with your car? spark plugs foul out or something?
Old Jun 21, 2007 | 01:53 AM
ikeryder13's Avatar
No not yet lol but its just not idling right i dont know and my check engine is just on
Old Jun 21, 2007 | 01:57 AM
chillfactor's Avatar
i got the same problem so i would love to know this too
Old Jun 21, 2007 | 01:59 AM
shaunmcdee's Avatar
whelp, im over here in riverside, so if you have some time over the week, your more than welcome to come by and i can take a look at it for you, or ill be going down to my moms in rialto on friday, so i can possibly swing by then, just lemme know.
Old Jun 21, 2007 | 02:17 AM
Robotech's Avatar
There are a ton of things that can cause a misfire. From something as simple as a couple bad plugs to holes in your pistons or broken valves. Now, I doubt it is something that sever but seriously, it could be anything.
Best bet is you have a warranty. Have you modified the car at all? If so what mods have you done? These things will make a difference. But really, you have a 100K mile Powertrain warranty on that car and this definately falls under that catagory...use it.
Old Jun 21, 2007 | 04:39 AM
loudestwine08's Avatar
well i hope you dont change the plugs your self , or have your red neck friend in his ion do i he he
Old Jun 21, 2007 | 11:15 AM
fivepointohman's Avatar
Take it to the dealer if its warrantied... Its your best bet for a free repair. I am sure they will find what's wrong with it, then make them tell you , and check to see if it was really change if they decied to replace stuff.
Old Jun 21, 2007 | 11:25 AM
PursuitGT's Avatar
A while back i got a misfire CEL. i took it in and they said it was for 1,3,4. they said it was because of my intake. I laughed in there faces and told them to clear the code. they did and it has never come back.
Old Jun 21, 2007 | 01:29 PM
ikeryder13's Avatar
Yeah just intake on the car so it should be covered
Old Jun 21, 2007 | 09:30 PM
Vin's Avatar
Vin
Get your check engine light (CEL) scanned if you really want to know what the computer is saying. Some places like Autozone do it for free. If you have full warranty take it to the dealer. It amazes me why someone would even ask. A car not idling right is likely a missfire which can be caused by many things. The most common is dirty spark plugs, old spark plugs, and spark plug wires will also cause this. A crack or split in plug wires will cause it. Performance plug wires not installed properlly.
Old Jun 23, 2007 | 09:01 PM
ikeryder13's Avatar
Well i just got my car back for the misfire problem... They had to re-adjust my crankshaft and clear the codes
Old Jun 23, 2007 | 09:29 PM
Coblasts's Avatar
Question Reajust the crankshaft ????
Can some one elaborate on this one !
Never heard of anything like that.
Old Jun 23, 2007 | 09:36 PM
Mikey851's Avatar
He is probably referring to the sensor, but I could be wrong.
Old Jun 23, 2007 | 09:40 PM
shortyheldberg's Avatar
I was having a mult mis-fire on my 2.4 for months the light would only come on after a while I had to take my cai off because it was the one that AEM used for the 2.4 in their R&D I got a ticket for not being CARB exempt there was slight moisture on the filter from car washes that use the undercarrage washer. low and behold 3 weeks later no more P0300 mult mis-fire so on a cai you can get the mult mis-fire code. If you have a cai check the filter especially at the front bottom. My stock set-up is on for now until I get the exempt sticker
I had a relearn on the crank also but it was only until a bit more moisture also I would be trying to see why the misfire would happen way before changing the cai and when I would let it warm up when the Idle would settle I would get the code on my reader if I wouldn't let it warm up for long I wouldnt get the misfire code as quick. I didn't want to believe it was the cai I'm now waiting for K&N to call me because they used my car also and I was told about 3 weeks for the K&N 2.4 intake Hopefully it will be sri
turbochargedss2012
Sep 20, 2023 12:17 PM
717ssbalt
Oct 2, 2015 04:01 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
