More boost than normal
Old Oct 1, 2012 | 07:10 PM
Twoozofjuice's Avatar
Ok so my car is a 2.4 2006 sedan and I installed the zzp stage 2 sc kit on it. It has a 3.1 pulley. Well I had installed a zzp downpipe and a badmab header a while back and my boost dropped down to 8psi which is where it was supposed to be at. Now out of nowhere my car is making 12 psi and slowly rises to 15psi as i go higher into rpms. I already checked to see if my cat was bad and it looks brand new still. Anyone have any suggestions on what could be causing me to have this abnormal boost?
Old Oct 1, 2012 | 07:15 PM
574's Avatar
574
Is it getting cold where your at? I know that causes higher boost but not sure how much
Old Oct 1, 2012 | 07:17 PM
lol if you call 90 degrees cold then yes haha
its been like this for about a month i just didnt think too much of it after i checked everything james told me to check.
When I log i would try and do it early in the morning or late at night because i didnt wanna log in 100 degree weather so it would usually be from 79 - 90 degrees
Old Oct 1, 2012 | 07:25 PM
Chevycobaltss3's Avatar
If your car gets more boost then usual. The only possible factor it can be is either colder air or a restriction in exhaust. Cat, etc
Old Oct 1, 2012 | 07:29 PM
must be a restriction then. there hasnt been any significant changes in weather. been lowest 79 highest 89 at night/morning when i log. Dont know if you remember that video i sent you of how the boost would rise from 12 to 15. Do you think its my exhaust that is causing the higher boost? maybe something is lodged in there because it was at 8psi for the a long time then out of nowhere went to 12 psi.
oh also I hear that the gmpp exhaust is 2.25 inch...do you think I would be able to replace the 2.25 inch with 2.5 inch piping and be good?
Old Oct 1, 2012 | 07:31 PM
I'd replace it with 2.5 mandrel if possible. Just get a magma flow setup from zzp
Magna*
Last edited by Chevycobaltss3; Oct 1, 2012 at 07:31 PM. Reason: Automerged Doublepost
Old Oct 1, 2012 | 07:32 PM
Bass_Waves's Avatar
maybe somebody shoved a potato in ur exhaust exit ???? lol
2.5 inch exhaust = less restrictive.
Old Oct 1, 2012 | 07:35 PM
I will look into replacing the piping...lol. I love the sound of my exhaust. Also would hate to have to sell it for like half of what I played for it .
I'm a little stuffed with school this week, have 3 exams, but I will get under the car and remove the exhaust and dp to see if I see any problems
Old Oct 1, 2012 | 07:38 PM
Yeah I know I'm going to try and replace my piping but I'm thinking something might've gotten stuck in cuz I was at 8psi with the header/dp/exhaust and I didn't change anything and my boost is at around 12psi and spiking now. Dk how something could've gotten in there though
Old Oct 1, 2012 | 07:58 PM
574's Avatar
574
Is it any faster??
Old Oct 1, 2012 | 08:04 PM
Originally Posted by 574
Is it any faster??
-_- lol its the same amt of boost going through!
reason for the all of a sudden concern on this is because I want to drop a pulley to 2.9 and I hear that getting around 15 psi on the stock engine in this car can be bad so i dont wanna be near that lol
Old Oct 1, 2012 | 10:16 PM
bluebalt07's Avatar
I wouldn't think 15 psi on a stock 2.4 would be that bad. Besides you can't really go based on boost, but have to go on power. 2.4s can handle a lot more power than a 2.2 so you should be ok with a 2.9. Good luck getting your high boost figured out
Old Oct 2, 2012 | 08:28 PM
06SS ALL DAY's Avatar
Go catless. Stop being a bitch.
Old Oct 2, 2012 | 09:08 PM
rather not have rasp
Old Oct 2, 2012 | 09:20 PM
nhanson's Avatar
Im about to go catless
I get about 14 lbs on my 2.2
Old Oct 2, 2012 | 09:21 PM
Pedobear's Avatar
sounds like lil gremlins in there with tiny hammers
Old Oct 3, 2012 | 07:23 AM
09BlkCrusader's Avatar
I don't mean to hijack this thread but I'm having the same issue but with the lnf stock Turbo on my 09 balt. Factory is 15 yet last night I was peaking 16-18psi and my vacuum was 21-23. According to the digital display it was around 70°f but I think it was a little colder than that. Not sure if normal. Also there is no popping coming from the exhaust. I switched my gas from wawa to mobile idk if no popping is good or bad. My main worry is the Turbo at this point.
Old Oct 3, 2012 | 07:41 AM
Sir_Hiro's Avatar
Accordin to cobe..if u over boost your car is a factory freak
Old Oct 3, 2012 | 07:52 AM
Haha so I saw but I would like to make sure everything is normal before I start ruining the powertrain warranty. It will normally stay between 12-14 but wot it goes over 15 in high 4th
Old Oct 3, 2012 | 07:54 AM
Sir_Hiro's Avatar
Well tbh..I wouldnt worry about a 1 Psi Spike.
EDIT: Oh you were spiking to 16-18? Yeah I have no idea >.<
Last edited by Sir_Hiro; Oct 3, 2012 at 07:56 AM. Reason: Didnt read the post right
Old Oct 3, 2012 | 07:56 AM
Yeah I think I'm too paranoid lol. I just like to make sure of things. My first Turbo car lol
Edit to your edit: lol yeah
Old Oct 3, 2012 | 08:02 AM
Sir_Hiro's Avatar
You'll be fine..The stock turbo can handle 22psi boosting..more then that you'll be buying a new turbo
Old Oct 3, 2012 | 08:26 AM
user 72239's Avatar
the LNF is set to make 260 hp from the factory. So if the ECM detects less than that due to weather, air density, temp. etc it will compensate. when i first bought my car, it was in January. I would regularly boost to 18 psi and stay 16 to redline. As it got hotter, the car spikes to 16 or 17 and then holds 14 to redline. That is how the factory ECM works.
So in a nutshell, it is normal. now if you car started going over 20 psi. then something is wrong.
Old Oct 3, 2012 | 08:28 AM
Okay thanks man much appreciated this brings my concerns down a shitload lol. I can be at peace for now. Just a few small other things I need to figure out lol..
Old Oct 3, 2012 | 08:32 AM
user 72239's Avatar
Yep. It is totally normal. when you are tuned it is a different story.
What other minor problems are you having?
