More boost than normal
Old Oct 3, 2012 | 08:55 AM
09BlkCrusader's Avatar
Well, when I stop at a red light and idle in neutral, I hear this clunking noise 2-3 times while I'm stopped. It feels like it's coming right from under me and I only hear it after coming to a stop. Not sure if it's coming from the exhaust or something. I'm still trying to figure it out so I can word it better lol.
Also, while parked, idling, every now and then i feel my seat vibrate a little, as if the engine had a rough cycle(s) for a moment. I thought this could be normal w/ the fuel injectors and all.
Old Oct 3, 2012 | 10:04 AM
prevsrt4owner's Avatar
Won't the ECM lower boost with cooler, denser air, not increase it?! Coming from an SRT 4, so don't be too hard on me, lol.
Old Oct 3, 2012 | 11:45 AM
user 72239's Avatar
I thought it should...it didn't make sense to me. but during the winter I boost higher than in summer.
Old Oct 3, 2012 | 05:12 PM
I always thought turbos loved cooler air, as cooler air is better? My logic behind that is from what people say which is why I didn't include why.
Gah my car has been too quiet lately.. Doesn't feel right
Old Oct 3, 2012 | 06:16 PM
bluebalt07's Avatar
I think that would be right also as the cooler air would make more power with less boost than hot air but who knows lol
Old Oct 3, 2012 | 09:20 PM
Twoozofjuice's Avatar
im guessing its because the cooler air is denser so its creating more pressure. since the hot air isnt as dense it needs to suck in more air to create a smaller amount of boost and with cooler air it sucks in less but creates more boost since the air is a bit heavier or something? im probably sounding like an idiot at this point. lol
Old Oct 4, 2012 | 07:46 AM
rukkee's Avatar
I've seen SS/SC's do this when the intercooler pump takes a **** ..... I would just double check that you have flow at the filler neck. GMPP exhaust should have been 2.5'' ..... It's too bad cause it does sound great , I had touring on my SC and loved the sound.
Old Oct 4, 2012 | 09:44 AM
my ic pump did take a ****. then i replaced it like in mid july with a new one from zzp so i dont think its that. temps stay low as hell while driving around and im in south texas where its hot as **** everyday so if it was out my temps would be over 200 easily lol. stay at around 183
and yes the gmpp does sound amazing...i want to see how much it would cost me to replace the piping to 2.5
Old Oct 4, 2012 | 08:52 PM
bluebalt07's Avatar
Your IAT2's stay at 183?! Or are you talking about coolant temp which has nothing to do with the ic pump
Old Oct 4, 2012 | 08:56 PM
lol yes was talking about that but i thought it did have something to do with it since when it went out last time my temps would skyrocket to 200+ driving like a grandpa.
my iats stay relatively low also. i dont remember the temps but yeah they dont get into that redzone or whatever much
Old Oct 4, 2012 | 09:04 PM
  #36
bluebalt07's Avatar
Ic pump might have a slight effect on coolant temps but not a direct effect. The only reason the coolant temps go up when the pump goes out is hotter air is entering the engine because of no intercooling. The coolant temp is not a good indicator of pump function though as several things can cause higher coolant temps. The only thing that points to a bad ic pump is the IAT2's
Old Oct 4, 2012 | 09:07 PM
  #37
in that case let me look over my last log but im pretty sure the pump is working fine
Old Oct 4, 2012 | 09:13 PM
  #38
hmm. when i started log my iats were at 102 then when i started driving they dropped to like 95. then when i did a pull they dropped to 77-79. yup doesnt go past like 81 during/after pulls so im guessing my pumps working fine
Old Oct 5, 2012 | 04:23 PM
  #39
rukkee's Avatar
Do you know around what PSI others are getting with a 3.1 on a 2.4L?
Old Oct 5, 2012 | 07:16 PM
  #40
nhanson's Avatar
Is that IAT coming from the intake manifold or from the MAF sensor?
Old Oct 6, 2012 | 01:00 PM
  #41
Idk lol. Its coming from hpt haha. Its like the gauge on the top right corner
Old Oct 6, 2012 | 01:24 PM
  #42
bluebalt07's Avatar
What map sensor are you using and did you have to do any rewiring for it? The only way to read IAT2's (air in the intake manifold after the supercharger and laminova cores) is with the 2.5 bar LSJ Tmap sensor. Stock map doesn't read IAT2's but the MAF reads IAT's (air just being sucked in to the intake).
Old Oct 6, 2012 | 01:27 PM
  #43
Using 2.5
I think it just plugged right in
Last edited by Twoozofjuice; Oct 6, 2012 at 01:27 PM. Reason: Automerged Doublepost
Old Oct 6, 2012 | 05:11 PM
  #44
nhanson's Avatar
Most likely your reading IAT1 which is your CAI temp and not intake manifold temp.
2.5 bar does just plug right in.
Old Oct 6, 2012 | 05:14 PM
  #45
how do i read my intake manifold temp?
Old Oct 6, 2012 | 05:56 PM
  #46
bluebalt07's Avatar
You have to wire the 2.5 bar map to read it. That map doesn't plug right in because it has a 4 pin connector and stock only has a 3. One of the pins on that four pin connector is for IAT2. You have to cut the IAT wire on the MAF connector and connect it to the IAT2 wire on the map connector. Just remembered you are running the ZZP bolt on kit so you probably are running the 2 bar map
Old Oct 6, 2012 | 06:04 PM
  #47
actually yeah i think i have the 2 bar lol i bought it a while back so i didnt really remember
Old Oct 6, 2012 | 07:02 PM
  #48
nhanson's Avatar
I have the 2.5 bar as my MAP and i read IAT in the intake manifold. Not hard to wire. Just have to find the 2.5 sensor and the connector for it.
Your temp youre reading now will read the intake manifold temp when you switch.
Solaris99
28
Mar 15, 2017 01:22 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
roth
Sep 26, 2015 12:16 PM
