My car is leaking inside
my a/c started leaking about 2 weeks ago in the passenger side where there feet go so ithought it was the runoff tube had come undone(think its called the runoff tube
) anyways i fixed that with no prob but then today it started leaking again today
but this time it was in a different spot... it was leaking out of the little hole in the a pillar where it says airbag i was like WTF!!! so i felt the spot where the fabric starts on the a pillar and it was soaking wet... so does anybody know what is going on and i might add that it has been raining for about 2 weeks straight where i live
plz post ur thoughts
but this time it was in a different spot... it was leaking out of the little hole in the a pillar where it says airbag i was like WTF!!! so i felt the spot where the fabric starts on the a pillar and it was soaking wet... so does anybody know what is going on and i might add that it has been raining for about 2 weeks straight where i live plz post ur thoughts
XM or Onstar antenna? If not, i'd start taking a look at the door seals. Actually, i'd bring it to the dealer and let them deal with it since it's still under warranty.
Take a garden hose and have a friend spray the outside of the car while you sit inside and try to see where the leak is coming from. That helps a lot to find the source of leaks..
i just went out and looked at my car and there is strip of the car that seperates the door from the roof go look at ur car so u know what im talking about
and i think that might be the problem
Thats the rubber weather seal.. check and make sure it's making a proper seal against the door. If it is, check and make sure the window isnt leaking around the seams.. Easiest way like i said is to have someone hold a hose over the area while you sit inside the car to check for water entering the car.
here's a link to the TSB for the water leak in the pass floorboard. Not sure about the A-pillar leaking unless it's your windshield leaking or the weatherstrip on the door opening.
http://fr33k.5gbfree.com/05-01-38-016b.htm
Turbo Johnny
Feb 21, 2019 09:41 AM
QuickSilver_SS
Jan 21, 2019 06:27 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
