My car is shaking please help!
Old Nov 11, 2015 | 09:20 AM
Corrinaannajo's Avatar
I drive a 2006 Chevy cobalt SS I just got all four brakes and rotors replaced and the swaybar links replaced and my car still shakes when I'm going down the road. It starts shaking at 45 MPH and stops around 60 MPH. It shakes even more when I am at those speeds and try to slow down. It doesn't do it as bad when I hit my brakes slightly harder to slow down. I do know I was told I need new caliper brackets on both sides in front. Any ideas what's wrong?
Old Nov 11, 2015 | 10:05 AM
jcobaltss's Avatar
Did you check your axles?
Old Nov 11, 2015 | 11:05 AM
cluelessk's Avatar
Sounds like you got a shop to do the work?
Take it back.
Old Nov 11, 2015 | 11:44 AM
You think I need new axles all together?
Old Nov 11, 2015 | 11:52 AM
cluelessk's Avatar
Could be axles, wheel bearings, could even be tires
Old Nov 11, 2015 | 12:21 PM
turboecotec02's Avatar
I know there's alot of things that can make your car shake but mine shook at exactly those speeds. I never would have thought this but my struts where completely toast. Replaced those and it doesn't shake 1 bit now. I don't know why blown struts would make it shake but in my case that's exactly what it was. Good luck
Old Nov 11, 2015 | 12:22 PM
JapEatr's Avatar
South Central *********
wheel bearings
Old Nov 12, 2015 | 02:19 PM
tomj77's Avatar
Clean the dirt out of ur rear rims.
Old Nov 14, 2015 | 01:32 PM
Something happened
Today I was going down the road and had to turn around and when I pulled into a place and turned around when I got back on the road my car was shaking almost no matter what speed I went and I had to drive like 25 the whole way home I think something broke even more.
Old Nov 14, 2015 | 04:26 PM
SR Tech's Avatar
One of the wheels not tight after brake replacement?
Old Nov 16, 2015 | 11:23 AM
Could it be that I need a front end alignment after having my sway bar links were replaced?
Old Nov 16, 2015 | 11:25 AM
That would help for sure
Old Nov 17, 2015 | 10:06 AM
I took it in and they said I need ball joints, struts, and calipers. Thanks everyone that threw out suggestions that's why I love this website.
Old Nov 21, 2015 | 09:54 PM
Jacque8080's Avatar
Did it get fixed?
MP81
Oct 27, 2023 02:10 PM
drewSSyboy
Dec 16, 2015 03:00 PM
SpeedyGonzalez
Nov 11, 2015 05:38 PM
firehawk618
Nov 11, 2015 12:52 PM
sheape
Nov 9, 2015 10:42 AM
