Is my motor hydrolocked?!?!
Old Jun 1, 2011 | 07:44 PM
mason753's Avatar
So last night I was driving through the pouring rain, I have a cold air intake. I had to drive there was no way around it so I tried driving and came to a street with alot of pretty pig puddles., my engine started sputtering, then I hit another puddle and it just shut off. I tried to start it and all it did was click. So I had road-side assistance and they towed it to my house. Today I tried to start it and still just a click. I pulled my intake tube off and the filter and a pretty good amount of water poured out of the throttle body. I checked oil and it seems real thin. I'm confused as if this can be fixed fairly easily or if I should start investing in a new motor. Please help.
Old Jun 1, 2011 | 07:46 PM
Bl4des's Avatar
should not have tried to start it after it died. take the plugs out and try cranking it to get the water out
Old Jun 1, 2011 | 07:48 PM
BLAZIN07SS's Avatar
I'm too JDM for you
pull out the spark plugs, leave them out overnight. attempt cranking it the next morning with the plugs still out of it and the injectors disconnected. you are going to have to crank it several times to try and get as much water as possible out of it. change the oil. put the plugs back in, plug the injectors back in and hope it fires
Old Jun 1, 2011 | 07:49 PM
ecot3c inside's Avatar
how "big" is "big" puddle?
gotboost?17's Avatar
Nothin Stock
damn bro that sucks in for results
Old Jun 1, 2011 | 07:51 PM
Murdered SS's Avatar
damn this suck i know it happened to me in texas and i took it to the dealer and the insurance covered all expenses i just paid the deductable.
Old Jun 1, 2011 | 08:23 PM
Sox-Fan's Avatar
Got Brakes?
I'd add to what blazin said by squirting a little oil or WD40 on the cylinder walls while the plugs are out over night.
Old Jun 2, 2011 | 11:48 AM
BartSS's Avatar
i would say ur gonna have to change your oil a couple times man
Old Jun 6, 2011 | 01:49 AM
Yea the dealship changed my oil 3 times when mine flooded
Old Jul 17, 2011 | 04:06 PM
mason753's Avatar
Motor won't even try to turn over, even with spark plugs out it just clicks. I haven't tried WD40, which sounds like a pretty good idea. I'll keep posting updates on what I find out.
Old Jul 17, 2011 | 07:45 PM
rukkee's Avatar
This seems to happen alot to SS/SC's . When i had mine I always thought if I got into a situation where water was going to be an issue .....I would just unhook the intake at the throttle body. Just an Idea incase someone reading this runs into the same situation . Even if you dont have a screwdriver .... a quarter should do it.
As far as it just clicking .... you might need to break it loose with a breaker bar and socket at the crank..... odds are the rods are bent if it sucked in a lot of water while running .
Solaris99
28
Mar 15, 2017 01:22 PM
ThoR294
Oct 4, 2015 08:44 PM
Stuff
Oct 1, 2015 05:47 PM
ThoR294
Sep 28, 2015 05:31 PM
SlowSaturn
Sep 28, 2015 11:03 AM
