Need help asap...... Sitting on side of road
Just filled up. When I pulled in car was idling a bit rough with slight ticking from fuel rail. Once gassed up and started was still running rough. Pulled away and hit the on ramp and got a weird sound like air escaping. No cel. Restarted and sounds terrible. Worse than an sti. Still no code. Plugged my code reader in and it shows p0303 cylinder 4 misfire. What is wrong. I'm stranded 3 hours from home.
spark plug went kaboom maybe, if thats the case u donn wanna drive the car coz it might mess it up even more...if it is the spark plug that blew up u gonna hear a lot of ticking and loud...
First guess sounds like its just an injector o-ring that let go... hold your hand over each injector and feel for air blowing by (specifically check #3 since that's where you're getting the code)..
Again, check the injectors... doesn't matter if they are stock or aftermarket - o-rings breakdown over time and become brittle, and they will split. This causes a major vacuum leak, which causes the car to stumble hard, and sputter, and you will also smell fuel because of the location. It will also pop a CEL. I've experienced this before, pop the hood, and feel for air over the injector.
