Need help asap...... Sitting on side of road
Old Aug 21, 2010 | 12:54 AM
SSinPA's Avatar
Just filled up. When I pulled in car was idling a bit rough with slight ticking from fuel rail. Once gassed up and started was still running rough. Pulled away and hit the on ramp and got a weird sound like air escaping. No cel. Restarted and sounds terrible. Worse than an sti. Still no code. Plugged my code reader in and it shows p0303 cylinder 4 misfire. What is wrong. I'm stranded 3 hours from home.
Old Aug 21, 2010 | 01:00 AM
SSinPA's Avatar
Please help
Old Aug 21, 2010 | 01:05 AM
exiged's Avatar
worst case scenario it sounds like #4 could possibly be blown. I would get in touch with friends / family. Maybe try unplugging the battery for a few minutes then try again.
Old Aug 21, 2010 | 01:09 AM
08slatecobalt's Avatar
Stranded 3 hours from home...where in PA are you at now?
Old Aug 21, 2010 | 01:11 AM
SSinPA's Avatar
Well in Florida with family. And why would it be #4 if it says number 3 misfire. I also smell fuel once started.
Old Aug 21, 2010 | 01:14 AM
SunburstSS's Avatar
spark plug went kaboom maybe, if thats the case u donn wanna drive the car coz it might mess it up even more...if it is the spark plug that blew up u gonna hear a lot of ticking and loud...
Old Aug 21, 2010 | 01:15 AM
exiged's Avatar
because you said #4 in the op. if you ment #3 then i would agree to check your plugs first, then injectors, then tune.
Old Aug 21, 2010 | 01:22 AM
Jazer's Avatar
First guess sounds like its just an injector o-ring that let go... hold your hand over each injector and feel for air blowing by (specifically check #3 since that's where you're getting the code)..
Old Aug 21, 2010 | 01:25 AM
SSinPA's Avatar
I'm on stock tune. Stock injectors and replaced plugs with stock type plugs about 20k or more ago
Old Aug 21, 2010 | 01:28 AM
Jazer's Avatar
Again, check the injectors... doesn't matter if they are stock or aftermarket - o-rings breakdown over time and become brittle, and they will split. This causes a major vacuum leak, which causes the car to stumble hard, and sputter, and you will also smell fuel because of the location. It will also pop a CEL. I've experienced this before, pop the hood, and feel for air over the injector.
Old Aug 21, 2010 | 01:36 AM
scottie's Avatar
have any tools with you? Did you check your plug/boot/coil?
Old Aug 21, 2010 | 01:41 AM
kapster's Avatar
Couldn't this also be the coil pack?
Old Aug 21, 2010 | 01:50 AM
SSinPA's Avatar
No I have no tools with me. Was just supposed to be a day trip. I don't even have a change of clothes with me.
Old Aug 21, 2010 | 01:52 AM
ramrod1337's Avatar
have you check the injectors like said before?
Old Aug 21, 2010 | 01:57 AM
SSinPA's Avatar
The injectors are under the plastic fuel rail cover. Can you still feel air? I'm in a hotel now. Gonna wait til tomorrow when things are open.
Old Aug 21, 2010 | 01:59 AM
scottie's Avatar
is the coil pack the same for the ss/ls? If so wouldn't they all be missing if it was one ignition pack.
northvibe's Avatar
post where in florida? maybe a florida member can come help out,
Old Aug 21, 2010 | 02:09 AM
SSinPA's Avatar
Exit 70 I-95 north on ramp. Staying at comfort inn on palm beach boulevard.
Old Aug 21, 2010 | 02:13 AM
scottie's Avatar
Wish I lived that way man, I'd come give you a hand. Quite a far drive for that though.
Old Aug 21, 2010 | 02:15 AM
SSinPA's Avatar
Thanks. Nice to know the brotherhood of the cobalt community.
Old Aug 21, 2010 | 02:26 AM
northvibe's Avatar
psot in the florida reagion
Old Aug 21, 2010 | 02:38 AM
northvibe's Avatar
Here ya go bud
https://www.cobaltss.net/forums/show...14#post5177014
Old Aug 21, 2010 | 09:12 AM
SSinPA's Avatar
Old Aug 21, 2010 | 11:24 AM
Brizzal's Avatar
I just saw this thread, did you fix your balt? Im in west palm beach
Old Aug 21, 2010 | 01:05 PM
scottie's Avatar
Any news?
