need help bad with possible no fuel to engine
i need help bad im stumped. i have a 06 cobalt with stage 2 and a 2.9 pulley. i dont know if i have bigger injectors or if the computer has been flashed but today i started my car after i had been driving around town for a little bit and my car ran real rough idle like if i didnt give it gas it died and then to move had to rev super high and died instantly when clutch was egaged. i pulled over and unscrewed and screwed in the gas cap and bingo problem was fixed. i drove around awhile later and after leaving the mall it did it again. i then i pulled overmand did the same thing with the cap and it works fine. i then went straight home. please help im nt sure if anything is wrong and wanted to see if anyone has had this problem before. thanks
no code that i know of no lights but im going to take it in to a parts store to have thm run a check for any. i check for fuel pressure and im als going to get injector cleaner today and try that. could there possibly be a problem with the gas cap not seeling
yea i have nothing no codes at all i just put fuel injector cleaner in this moning and it still hasnt fixed the problem it just did it to me again about an hour ago. what happens is beow 3000 it acts like it gets no gas and isnt firing righ then when you give it wot and rev it up it runs fine. i pulled over undid the cap and re did and now its working good again. tomorrow im going to see about getting the fuel pressure level checked and if thats goodthen im going to take it in to th dealer, im just hoping it does it for them. but thanks for the help so far.
patooyee
Oct 1, 2015 01:07 PM
