need help dip stick keeps popping out
i don't know y it is doing this i thought it was because of the intake manifold gasket because that is what people said but i changed that like a week or 2 ago and i just came back from a drive i got on it a little bit but not much and i popped my hood and the dip stick is out and i have oil in my engine bay again what can i do to fix this
i dont think i am burning oil i know that but my mods are 2.8, 60's, trifecta tuned, zzp header and downpipe, magnaflow catback, zzp heat exchanger, dual pass, raw intake, and hactickstu mod
i have an interceptor and wideband everything seems fine and it has only happened in like the last month and a half and it happen before and after i was tuned
Another thing to note is that GM revised the IM gasket to improve the CV. You may need to replace that depending on your model year...
http://www.crateenginedepot.com/stor...P1723C137.aspx
i already replaced it i said that in my first post were can i get a breather filter cap i went to autozone and they didn't have any only ones that push in for older cars
where can i get the breather cap to replace the oil cap
here all you need to know about it https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/alert%2A%2Adipstick-popping-out-here-solution-39770/
Check your PCV valve. If its plugged and not working it cant vent the crank case pressure, which would make it seek any outlet it can and since the dipstick isnt really held in by much it would go there.
I'm not sure of the other engines, but the LSJ does not have a PCVV.
