need help fast!!!
Old Apr 13, 2007 | 04:48 PM
DomDiggity's Avatar
need help fast!!!
I'm installing my stage 3 kit now and I can't get the pully off. There is a push in plug that I cant get off. please help
Old Apr 13, 2007 | 04:49 PM
Tomtwtwtw's Avatar
The plastic one at the end of the s/c snout? It screws out...yeah, it had me confused for a while at first, too. Just get a really thin pair of pliers to get it started, then you should be able to use your hand from there.
Old Apr 13, 2007 | 09:24 PM
DomDiggity's Avatar
thanks
new problem can't get my tensioner back on I took off this hex bolt under the tensioner pully and I cant bring the pully back up to where it was originally.
someone
Last edited by DomDiggity; Apr 13, 2007 at 09:24 PM. Reason: Automerged Doublepost
Old Apr 13, 2007 | 09:39 PM
Red2.4SS/SC's Avatar
bump for this guy im having the same problem , we took off the original tensioner pulley and tried to install the intense 3 in one and there is no way this belt is gonna go over it , ive tried the 15mm wrench , its too loose around the bolt that you have to push down , DOES ANYONE KNOW HOW TO INSTALL THE BELT AFTER INSTALLING THE 3INCH TENSIONER PULLEY FROM INTENSE
Old Apr 13, 2007 | 10:20 PM
DomDiggity's Avatar
Finally got it. It took three guys to do it.
Old Apr 13, 2007 | 10:36 PM
Does Anyone Know How To Install The Belt After Installing The 3inch Tensioner Pulley From Intense
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
OrangeCoba
Sep 29, 2015 03:56 PM
Sep 27, 2015 08:53 PM
no_ss
Sep 18, 2015 11:03 AM
