need help immediate
Old May 20, 2011 | 03:37 PM
Souperman's Avatar
need help immediate
Im at the beach for cruise weekend and well my problem is my car after cruise for awhile I boost in 2nd get full boost and go goes in limp mode at 4 grand. No codes are thrown, and all piping is still connected.
Old May 20, 2011 | 03:39 PM
NinjaHampster's Avatar
try disconnecting the battery to see if it will reset
Old May 21, 2011 | 12:08 AM
work????
Old May 21, 2011 | 12:33 AM
Souperman's Avatar
Sorry man phone died but it did for alil bit but happened again. I have not the slightest clue what's going on. Its **** e the randomly it will do it both tune off and on
Old May 21, 2011 | 10:51 AM
Souperman's Avatar
Old May 22, 2011 | 01:33 PM
Souperman's Avatar
Bump. Only has all of second for a pull pulls and then only half after that. Battery didn't work.
Old May 22, 2011 | 01:46 PM
CanadianCobalt's Avatar
When it goes into limp mode no codes are thrown then? There should be something.
Are all sensors plugged in? Mine did exactly this after I had worked on it and forgot to plug in the sensor on top of my SC (I know you have a TC). Have you done any recent work to it? Try reseating the sensors.
Joel
Old May 22, 2011 | 02:06 PM
Souperman's Avatar
Have done any recent work to it in about 3 weeks since intercooler install but never disconnected any sensors but ill recheck
Old May 22, 2011 | 09:06 PM
Souperman's Avatar
Anyone else have any input? Could it be a bad plug? My first thought is a misfire cause its does sputter like it could be. But its only in 2nd gear. I did third and fourth gear pulls today and they were all fine through the whole gear
Old May 23, 2011 | 01:33 AM
did you try having it scanned to see if the computer saved any codes? it will still have codes as (pending) but wont throw the CEL
Old May 23, 2011 | 08:58 AM
Coblasts's Avatar
Is your intercooler pump working?
Old May 23, 2011 | 09:01 AM
ecot3c inside's Avatar
lol.
Old May 23, 2011 | 10:03 AM
Coblasts's Avatar
If it was misfiring bad enough to go into limp mode the SES light would of been flashing I would think.
No codes?
Old May 23, 2011 | 11:51 AM
Souperman's Avatar
I had a code couple days before for maf sensor and figured it was cause I cleaned my k&n with the recharge kit. Other then that haven't had a code thrown
Old May 23, 2011 | 01:19 PM
BartSS's Avatar
Scan your computer and tell me if it stored P0236. Mine did and it didnt throw a CEL. It was a bad lower MAP sensor. $16 fix bro
I had the same problem. It would build boost and then backfire and go into limp mode
Old May 23, 2011 | 11:01 PM
Souperman's Avatar
Ok thank you and ill def check it out appreciate the help everyone ill inform you if there's anything
Old Jun 16, 2011 | 11:37 AM
Souperman's Avatar
Where can I buy the cold side map sensor? I see them online but not sure if its just any kind of map sensor if if its a certain one? Any opinion is appricated
Old Jul 2, 2011 | 11:49 PM
Souperman's Avatar
I've replaced my spark plugs and my lower map sensor yet still having the problem but mainly when I turn my tune on well everytime I use the tune it does it. Question im now asking is do the tunes start to act up? I haven't had it retuned since before I for full exhaust and a intercooler. Is it possible that those cause my tune to do what its doing?
Old Jul 3, 2011 | 12:49 AM
cobalt2010's Avatar
intercooler could have somethin to do with it, although i dont have a TC. considering you upgraded the intercooler
Old Jul 3, 2011 | 01:21 AM
megaman311's Avatar
Supercharger inlet sensor is more than likely the culprit
