need help with meth kit
Old Oct 15, 2009 | 02:46 PM
Bl4des's Avatar
i am installing my progressive meth kit with the ais trunk mount kit know i need to know where would be the best place to power it from and what wire is the one for the map sensor
Old Oct 15, 2009 | 02:47 PM
G85 SS's Avatar
sunroof.
Old Oct 15, 2009 | 02:50 PM
BLAZIN07SS's Avatar
I'm too JDM for you
get power from the sunroof or wiper fuse. those are only on with the key on ACC. and its the gray wire on the map sensor connector
Old Oct 15, 2009 | 03:03 PM
Bl4des's Avatar
and i want to know for people that have the progressive kit where did you mount the controller
Old Oct 15, 2009 | 03:12 PM
BLAZIN07SS's Avatar
I'm too JDM for you
put it on the tank but i have seen some that mount it up front so that they know when the pump is coming on
Old Oct 15, 2009 | 03:14 PM
G85 SS's Avatar
Mine is mounted on the tank.
As Joshua said, some mount it up front so they can control it and see if the pump is coming on.
Old Oct 15, 2009 | 03:37 PM
Bl4des's Avatar
i think i am going to mount it on the tank so if i take power from the sun roof what wire do i tapped into and where is the wire
Old Oct 15, 2009 | 03:40 PM
BLAZIN07SS's Avatar
I'm too JDM for you
use an add-a-circuit and get power from the fuse box on the passenger side of the center console
Bl4des's Avatar
ok thanks for the help
Old Oct 16, 2009 | 12:47 PM
Bl4des's Avatar
does any one have a photo of where they tap the map sensor i am doing it now
Old Oct 16, 2009 | 02:06 PM
BLAZIN07SS's Avatar
I'm too JDM for you
check out the devils own site(alcohol-injection.com?) they have the map sensor wiring. you have to splice into the map sensor wire. its gray, connector number 4
Old Oct 16, 2009 | 03:22 PM
Bl4des's Avatar
where should i get to the wire tho like right where the map sensor goes into the manifold
ok i am done installing it besides hooking up the map sensor wire where do i connect it
and what size nozzle do people use i was going to use the 7gph is that top big
Old Oct 16, 2009 | 03:24 PM
blue05ss/sc's Avatar
what ur getting no love? lol
Old Oct 16, 2009 | 03:38 PM
BLAZIN07SS's Avatar
I'm too JDM for you
peel back the tape a little on the map sensor wiring and do it a couple of inches back from the sensor.. make sure its a solid connection. you dont want it coming lose and no meth spray.
Old Oct 16, 2009 | 04:53 PM
Bl4des's Avatar
ok i got it all hook up io am just letting my car warm up and i am going to see if everything is right
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
