no crank/no start
Check the fuel pump relay to see if its seated properly.
Also this connection below.
First thing before deep diving into the diagnostic, please check for a possible loose terminal at the Underhood Bussed Electrical Center (UBEC) for the fuel pump power supply. There have been reports that this terminal for circuit 120 (Gry) has been loose at the UBEC.
At leat give the underhood fuse box a continous rap or shake while trying to start the car.
does the vehicle do anything? Does it make a loud click when you try to start it? If so its most likely the starter. Are there any lights (dome light, dash light, Check engine light)? If not then its most likely a poor battery connection or popped fuses.
Make sure the connections at the battery are good. You can try disconnecting the battery for a few minutes then reconnect it. It will clear any codes and if the car isn't starting due to a sensor malfunction it should start up now.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
