No More 2nd, 4th, or reverse
Old Apr 7, 2006 | 09:14 AM
R33P3R007's Avatar
360 L337 User
Like it says, coming home last night i shifted into 4th on the highway and it isn't there. When I slowed down and downshifted i didn't have 2nd either.
I installed my B&M shortthrow about 6 months ago. It had to be readjusted one time but other then that, nothing up until last night. I figured that one of the clips was broken or came off, but they are fine, and the cables both move. If you look in the engine bay the 2 cables come out the firewall, and into a block, or somthing, that holds the cables. One cable looks fine when you go through the gears, but the other one flops around and comes out like 6 inches at the holder.
Could I really have broken the Cable?
Anyone ever replace one?
I really need help with this, I don't understand front heel drive that well, and Until I get a new downpipe, I can't take it to the dealer.
Plus, do you think they will blame it on my shifter, I don't think the shifter should have anything to do with it, since it is all oem spec, just a shorter throw. Should I put the stock one back in first?
WTF... anyone want to buy a broken car.
any info would be great
Old Apr 7, 2006 | 10:09 AM
silverSS's Avatar
Im sure it has to do with you installing the B&M I have never had a problem with my shifts. (stock)
I would return it to stock before bringing it in for service
Old Apr 7, 2006 | 10:18 AM
Ern's Avatar
Ern
Not sure how the B&M could cuase it. I marked my cables with permanent marker and to me as long as the cables are still in the same spot as before nothing has changed. Only thing that has changed is the lenght of the shifter. My marked cables are snapped in place just as they were stock.
Old Apr 7, 2006 | 10:21 AM
p7x's Avatar
p7x
WTF!!! I have seen this type of thread many times and it really worries me. Has anyone had a fix and been told the problem.
R33P3R007 sorry to hear it man let me know what the problem is when you find out.
WJT DEMON's Avatar
Things break.
Old Apr 7, 2006 | 10:28 AM
blkcobalt's Avatar
Maybe I missed something somewhere. Why do you need to replace down pipe? Did you replace it with aftmkt or something. And if so......dealer should still work on your Cobalt.
Old Apr 7, 2006 | 11:25 AM
R33P3R007's Avatar
360 L337 User
No, I was overboosting and smoked the cat, causing the gaskets and the flex pipe to go. They said it was because i used leaded fuel... I don't even know where to get it, or a reason why i would use it, so they never fixed it.
I then deleted the cat, since they won't warrenty the Downpipe so the CEL light is on for that. I don't want to take it in with the Exhaust leak and no cat, just in case I have problems later.
Old Apr 7, 2006 | 11:29 AM
2K5SS/SC?'s Avatar
Get the down pipe fixed first, and then screw on the stock knob. It will twist on the threads on the B&M shifter without ruining the threads. I know the stock knob has no threads, but it will go on there. Then take it in for service.
Old Apr 7, 2006 | 11:32 AM
R33P3R007's Avatar
360 L337 User
good idea. I need the Downpipe part number if anyone can help. Someone is going to try and get me a deal.
PlaysWitCars's Avatar
Former Cobalt Owner
hmmm i was going to install my b&m tonight too.....should i wait? or just go ahead with it? any tips when installing?
Old Apr 7, 2006 | 11:40 AM
R33P3R007's Avatar
360 L337 User
nope, the install instructions are really good.
well, be carefull with your stock shift ***, and make sure you mark the cables well before you take them out. but they tell you that
Old Apr 7, 2006 | 11:48 AM
Former Cobalt Owner
cool thanks!
Old Apr 7, 2006 | 11:53 AM
06black's Avatar
HERES THE ANSWER!!!!!!!!!!!!!!!!!!
i was one of the first to have such a problum....both with stock and with my B&Msts
the cables clip on to these lever looking things on the trans....when the move it changes a gear...simple enough....the problum is that the leaver things are held on the the trans by a very shity little hallow roll pin....it breaks/bends very easy.....if you want try and replace the pin your self...get under the car and you can do it....if you take it to the dealer PUT THE STOCK SHIFTER BACK ON....my reason for that is simple..... when i took my car in for the 3rd roll pin(I'm on my 5th now ) it had the B&M on....it broke the first cupple times with the stock shifter...the only reason i still have a warrenty on my trans is bcasue a friend of mine at the dealership gave me a heads up and i came and got the car before the dervis rep came in....so long story short....i
its not the calbes...its this roll pin...the calbes are quite strong....put the stocker back on and get it fixed then swap the B&M back....i've done it many times now and it can be done in about 20min once you've done it a few times.
good luck, PM for help if you need
Old Apr 7, 2006 | 12:09 PM
R33P3R007's Avatar
360 L337 User
PMED...... Is the same thing that happened to me what happened to you. I can't really tell until it is on a lift, but you think the pin can be easily replace myself?
Old Apr 8, 2006 | 09:34 PM
djt81185's Avatar
Same thing happened to me at the track today. Got under the car and the black cable actually had a piece that was broken off on it. About 1/2 inch long on the side closest to the tranny. I have a B&M. I only have it cause the dealership glued my stock knob back on and I had to sawzall it off.
I was able to somewhat fix it by ramming the plastic piece back onto the linkage holder that it popped out of and made it home but it just popped out again. Any ideas. I mean I have a broked piece of plastic on my shift cables.
Dan
Old Apr 8, 2006 | 09:41 PM
97CIVIC's Avatar
put the stock one and see if its better
Old Apr 8, 2006 | 09:45 PM
djt81185's Avatar
kd;fadfladnflandf
Old Apr 8, 2006 | 10:38 PM
06black's Avatar
as far as the brokin pice on the linkige...thats a little odd....i havent even done that yet....i can say that waly edgar has an extra linkige cuz i gave it to them(long story)
put your stocker back on and take her in...if they cant order the part fast...tell them to get it from wally edgar
Old Apr 17, 2006 | 12:27 PM
R33P3R007's Avatar
360 L337 User
The linkage was broken down by the trans.. just like djt81185 said. They finally ordered the new one and got it in, but now they are having problems getting it into reverse. WTF. and they said their directions say something about a neutral switch that they can't find on my B & M.
Anyone have an idea of what they are talking about. i did exactly what the B & M directions said when I installed it. I Don't know why it won't go into reverse.
HELP!!!
Old Apr 17, 2006 | 01:31 PM
R33P3R007's Avatar
360 L337 User
Help..... Someone... Anyone.....
Old Apr 17, 2006 | 02:13 PM
R33P3R007's Avatar
360 L337 User
someone help a brother out.
Old Apr 17, 2006 | 03:17 PM
CloudyDaysBehind's Avatar
Why don't you email B&M and tell them about the switch/what GM told you. They may have an idea on what needs to be done...
Old Apr 17, 2006 | 03:18 PM
R33P3R007's Avatar
360 L337 User
Holy ****.. thats a great idea. I wonder if they will actually get back to me?
Old Apr 17, 2006 | 04:53 PM
Former Cobalt Owner
I lost 2nd, 4th and reverse this weekend....i went to shift into 4th getting on the highway and all i got was nothing....but i had 1st 3rd and 5th. so i pulled off the highway into a parking lot and pulled out my cupholder to find that the linkage popped out of the bracket. All i had to do was pop it back in. So i havent done any hard shifts since.
Old Apr 17, 2006 | 05:06 PM
yellowcobaltss05's Avatar
this happened to me about a month ago and the dealership said right away that my shift cable snapped and if you take it to the dealership, put the stock shifter back on.
