no power steering after working being done
I took my car to a local speed shop to have the clutch changed. They also changed out the IC Pump, radiator, heat exchanger and ac condenser. While they were doing that I also had them install an AEM wide band and run the cable to the cab.
I put it up right as they were closing because I need the car this weekend. They did test drive it, but when I called them there wasn't anyone answering for me to see if the power steering was working during the test drive.
I'm thinking the most likely thing is 1.) Fuse. 2.) Connect to the electric motor isn't plugged in.
I've never seen the power steering motor before. The pictures I've found on google show the unit, but not installed. Is the motor located instead the cab, or is in the engine bay?
http://personal.linkline.com/yankeeman/Koyo01.jpg
I'm thinking it's in the cab.
Maybe they forgot to connect the power to it. It a plug that's on the fuse box on the top left side (standing in the front facing the car) is your steering wheel really hard to turn?
Would be inside the cab
