no start after valve cleaning
So i cleaned my intake valves this weekend, they were pretty bad.
I put it all back together, and now my car wont start. It kicks over like its trying to, and will start for a second but it sputters out and then dies.
I have tried:
Unhooking battery
Checking all connections
Checking fuses
letting it sit for awhile so the fuel pump can prime
fuel leaks out if I unhook the fuel lines, so I know its getting fuel
Spark plugs are good.
any suggestions would be helpful
I have tried:
Unhooking battery
Checking fuses
No that wouldn't be it, I had mine same way. Make sure u didn't forget brake booster line , did u replace the pcv valve? Make sure u didn't forget to put that back in if u removed it. U put the fuel pump relay back in?
DANRICKARD
Oct 1, 2015 12:08 AM
