No supercharger coolant.
Old 10-13-2012, 02:52 PM
nhanson's Avatar
Add water and see if it circulates.
Old 10-13-2012, 03:01 PM
Andrewjw09's Avatar
Okay, thanks for everything guys. I'm gonna go get some coolant from autozone. Dex 50/50 right?
And this might sound like a stupid question, but this is my first car... I just pour that coolant into that same place I just posted the pictures of right? The coolant reservoir for the radiator is separate from the supercharger coolant, correct?
Old 10-13-2012, 03:04 PM
carstedt's Avatar
Wow that looks shitty
Old 10-13-2012, 03:05 PM
1LowLS's Avatar
Correct. and yes dexcool 50/50.you can just try straight water to see if there is a leak first.Seeing I live in AZ as well,it's not cold enough to freeze water.You can have the car running while you add to help circulate it and get air pockets out as well
Old 10-13-2012, 03:09 PM
Andrewjw09's Avatar
Could I use just regular tap water?
Old 10-13-2012, 03:12 PM
1LowLS's Avatar
Distilled.You can use tap water but it tends to have calcium build up.
Oh and question,do you have a front lip or is it missing?
Old 10-13-2012, 03:54 PM
Andrewjw09's Avatar
The lip isn't missing. There is, however, no cover/grill in front of the HE, like on this...
The front bottom on mine looks more like this
Old 10-13-2012, 03:56 PM
Andrewjw09's Avatar
And how much water do I put in, then?
Old 10-13-2012, 03:57 PM
nhanson's Avatar
Just do tap water to see if its working then in a short while change it out for straight distilled (if your temps dont get to freezing)
Old 10-13-2012, 04:52 PM
1LowLS's Avatar
Ok I've been seeing a red one out in the gilbert area a bit getting on it everytime he's see's me.One day I'll catch him and give him an asswhoopin lol.
Old 10-13-2012, 05:24 PM
  #36
Andrewjw09's Avatar
LOL, mine is red and I live in the chandler/gilbert area... but I haven't gotten on it in a couple weeks due to a worn out clutch that I'm replacing monday. Might have been me? lol but I'm not missing the front lip.
Edit: Come help me with this coolant business ha.
Old 10-13-2012, 05:35 PM
  #37
bluebalt07's Avatar
Just fill it up with tap water first to check for leaks and see if the pump is running then switch to distilled and throw some water wetter into too
Old 10-13-2012, 05:46 PM
  #38
Andrewjw09's Avatar
When you say switch, you mean I'd have to drain the tap water out? How do I do that? lol
I'm a complete noob.
Old 10-13-2012, 05:52 PM
  #39
1LowLS's Avatar
You would have to pull a hose.And this red one I see is/was missing the front lower lip.If I wasn't such a lazy ass I would come help haha.
Old 10-13-2012, 06:07 PM
  #40
bluebalt07's Avatar
Yeah like low said just pull a hose off. One of the two connected to the pump in the best way to drain because that's the lowest point of the system
Old 10-13-2012, 06:34 PM
  #41
Andrewjw09's Avatar
Well, the pump isn't working. It didn't take much water to fill it up either.... how much does it usually hold?
Old 10-13-2012, 06:45 PM
  #42
bluebalt07's Avatar
Should say in the owners manual but I can't remember. It probably takes more than will go in right now because if the pump isn't working, it's only going down to the pump and just sitting there, not going into the rest of the system
Old 10-13-2012, 07:45 PM
  #43
nhanson's Avatar
If you have the funds you might as well get a dual pass. when you replace the pump
Old 10-13-2012, 08:06 PM
  #44
Andrewjw09's Avatar
How much is that?
Old 10-13-2012, 09:42 PM
  #45
bluebalt07's Avatar
$100 from ZZP. Price must've gone up
Old 10-14-2012, 01:03 AM
  #46
ionREDLINEracer's Avatar
ZZP has been out of stock for a couple of weeks now.
Old 10-03-2013, 10:51 PM
  #47
Ritty06SC's Avatar
I'm having the same issue. Not any "curtsies", just no coolant flowing through. What coolant can I use to fill it up? And can I fill it right in that neck in front of the sc?
Old 10-06-2013, 02:27 AM
  #48
05RLS2's Avatar
Yes, read the owners manual or download it from the chevy website
Old 10-06-2013, 09:54 AM
  #49
BARON420's Avatar
just a side note...
do NOT over tighten your coolant cap for sc, for years i wondered
and asked about coolant for sc, close the cap do not tighten!!
Old 10-06-2013, 10:14 AM
  #50
the filler neck cap?
Quick Reply: No supercharger coolant.
