Noise when accelorating...
Old Jun 13, 2006 | 11:55 AM
firesting's Avatar
Hey all, one quick question. I noticed yesterday that when I give some gas to the car, it makes a sound as if air is being forcefully pushed out from somewhere... Maybe the muffler? I dunno... But one thing I know for sure, it's not the sound of the s/c. Anyone else hear this? I'm taking it in to fix some other stuff, so I guess I'll tell them about that...
Old Jun 13, 2006 | 11:58 AM
CTCOBALTSSS's Avatar
No, sorry bro. Must be some kind of leak somewhere or something.
Old Jun 13, 2006 | 12:04 PM
cybcow's Avatar
One of your windows is open just a crack. Close it and that should solve the problem.
Check for one of the screws towards the front of the car rubbing on the rubber intake tube.
Old Jun 13, 2006 | 12:46 PM
JohnyNFullEffect's Avatar
Does it sound like it is near the feet section of the passenger? I have the same thing. I think it is the exhaust through the exhaust pipes. if you are driving and then let off the gas, it is gone. then when you give it gas, it is back. Most likely that.
Old Jun 13, 2006 | 01:50 PM
firesting's Avatar
yeah! well, it sounds like it's coming from the back right of the car. But you're exactly right, as soon as you let go of the gas, it stops. Push the pedal down again, and there it is. I notice it's only there for me when I'm pushing the car. If i'm driving normally or slower than usual, it's not really there... I'm gunna call my GM dealer soon!!!
Old Jun 13, 2006 | 02:03 PM
jokieman's Avatar
Sounds like the exhaust. Maybe you've got a bit of a leak.
Old Jun 13, 2006 | 02:28 PM
firesting's Avatar
lets say i do... is that bad? i mean it won't hurt the car more? I can drive it to and from work? but i will bring it in asap
Old Jun 13, 2006 | 02:34 PM
p7x's Avatar
p7x
I dont think anyone knows for sure, but even C&D or MT experienced it in one of their tests.
Old Jun 13, 2006 | 07:24 PM
firesting's Avatar
I think it's not actually a problem, just the normal sound of the muffler lol! I was listening more carefully, and it sounds like it's just a normal sound... bope... i'll keep my ears open
Old Jun 14, 2006 | 03:04 AM
PenguinPIE's Avatar
is it the hissing noise that ur talking about?....coz im hearing it ...around the passenger side and it goes louder as the rpm gains......then it dies down as the rpm drops....
Old Jun 14, 2006 | 08:30 AM
firesting's Avatar
yeah it's a hissing... like air is being pushed out somewhere... but i think it's just the muffler or pipes... ?? i got an appointment to bring my car in on the 26th, since i'm off that day. i'll ask about all of this...
Old Jun 14, 2006 | 01:55 PM
jokieman's Avatar
If it's a hole, it shouldn't. Fuel economy might go down a tad, bout it. If it's not a hole, there may be some sound deadening insulation missing in the floor board area.
One of the things I really like about our cobalt is that it's very quiet inside the cabin even at highway speeds compared to other vehicles in this segment.
Old Jun 14, 2006 | 03:06 PM
RedBaseBolt's Avatar
As far as I can tell it sounds like either exhaust or tranny.
In my case I only here it when I give it a little gas or when I'm accelerating.
I always assumed it was just the auto tranny, but I guess I could be wrong in this case....
Old Jun 15, 2006 | 10:10 PM
pfactionbrett's Avatar
I can't believe nobody's mentioned fuel pump/fuel lines...because i'm pretty sure thats what it is I get it too...
Old Jun 16, 2006 | 01:10 AM
Switt23's Avatar
My guess would be alternator whine since the battery is clear in the back. Alternator in the front of the car.... battery in the back, sounds like a biggy option to me.
Old Jun 17, 2006 | 01:33 PM
darklordxenocide's Avatar
ok, well, i have a 2.4 and it does the same thing.... but.... it is not when i reach high rpm's, it only does it when i hammer it in the low rpm's, for example in a high gear... cuz it is forcing too much air through with not enough power
Old Jun 18, 2006 | 12:27 AM
player_1's Avatar
GET IT CHECKED ASAP !!!
check to see if you only get the hissing or whistling noise when you start to put boost. I had a similar problem and it was my CAT that was clogging up, if your cat cloggs while your driving it's major bad news for you engine
Old Jun 18, 2006 | 12:37 AM
PenguinPIE's Avatar
but i dont have a blower....
ill tell them to check the cat anyways
Old Jun 18, 2006 | 09:11 AM
rockstarbass1's Avatar
haha i have the same ******* problem!!!!!!!!!! between 2k and about 3k it does it! sounds like its comming from up front. well my car is at the dealership getting that checked out and oil change, all new trim pieces, new door handle, whole trunk repainted, something with the top of the car either repainted or cleared. and washed and waxed. FOR FREE! when i get it back wed or thursday ill post what they tell me the sound is!
Old Jun 18, 2006 | 09:12 AM
same exact problem that i have!
Old Jun 18, 2006 | 11:02 AM
mike25's Avatar
i would say its a hole somewhere in the top of the tank...if air is being pushed out when you put gas in ...then air is getting in somewhere when you start getting an empty tank...and when you put gas in the air is being pushed back out...that sucks i dont know how that could have evr happened
Old Jun 19, 2006 | 06:42 PM
i think that with us... it is just too much air being forced through at low rpm's, nothin to worry about i would think, just take er' easy when in high gears at low rpm's. it doesnt sound like the exhaust for the 2.4's, it sounds like it is coming from the intake almost...
Old Jun 24, 2006 | 07:00 AM
bigworm's Avatar
interesting, i put a billet mount on my car tonight and im having this same issue.
my 2.4 sounds like the intake is hella loud now when i hit the gas, didnt hear this before. granted i dont recall ever turning off my radio before tonight as well... hrm.
Old Jun 25, 2006 | 12:34 AM
tiny's Avatar
i have the same thing, i think its caused by being in a high gear at low rpms while accelerating
Old Jun 25, 2006 | 10:41 AM
06CobaltssOrange's Avatar
hey
this happened to my car he means its a really really loud whistle this sounds like a j brake when the air is being blown out of it its louder way louder then ur supercharger my car had it and my car was having problems getting up hills and didnt like 55mph like when u threw it to 2nd and hit the throttle the car would do it so it threw a cel now its at my dealer! if it doesnt get fixed there giving my money back from my car and u will se a mitsubishi evo in my driveway!
