Not sure what is wrong
Old Mar 28, 2008 | 05:53 PM
biniecki's Avatar
Here is my story. Wednesday I was driving down the eway and out of nowhere all my gauges bottom out, danced around a bit and the ABS light came on. The car never shut off and it only lasted a minute or so and everything went back to normal. I noticed that it seemed to happen when the gauge lights turned so I tried to replicate the problem later on in the day by putting something over the sensor and nothing happened when the lights came on again.
I thought nothing more of it with the car being fine the rest of the day and throughout Thursday. However more problems occurred today. The car was fine all day until I was driving home. I stopped at a stop sign and when i went to go threw the intersection and the gauges and ABS light did the same exact thing however this time the door locks decided to unlock and then lock again. Again the car never turned off and within a minute or so everything was fine again.
I continued home and stopped at a gas station to fill up. When i went to leave the car didn't want to even attempt to turn over and there was power because my radio and everything was working. I checked the battery just to be sure and everything was nice and secure. I then checked the fuse box. It didn't look like any fuses were blown but i decided to swap the run relay with another one and try it starting the car again thinking that the relay may have died. I tried it and the car started. Sticking with this idea i then turned the car back off and swapped the relays back to their original spots and tried starting the car again. The car started fine again with was a shock. I then drove the rest of the way home and nothing strange happened.
Anyone have any idea at all what the problem might be. I called the dealership and they pretty much said they could do nothing until the car did it on a regular basis or if the car wouldn't start to determine the problem.
Old Mar 28, 2008 | 07:30 PM
Coblasts's Avatar
I am going with Igniton switch faulty,I will look up the schematic when I get home see how it al relates to your problem.
You have alot of weight on your key chain?
Old Mar 28, 2008 | 07:33 PM
madmark's Avatar
i would suspect the bcm at first, but if there were any codes you could give us that would be best. like short to ground or battery would help alot
Old Mar 28, 2008 | 07:34 PM
jimbos'ss's Avatar
i'm gonna have to go with gremlins.............................
Old Mar 28, 2008 | 08:32 PM
biniecki's Avatar
I do have a lot of weight on my key ring with all the keys for work, 3 cars, and 3 houses. As for CEL codes it never threw any codes
Old Mar 28, 2008 | 08:34 PM
KillerBee's Avatar
wounder if you got a chipmunck or field mouse chewing on your inginition or wireing harness
Old Mar 28, 2008 | 08:41 PM
biniecki's Avatar
I was thinking of maybe some bad / loose ground wires but I dont have a clue were all of them are located
Old Mar 28, 2008 | 08:45 PM
SSRedSC's Avatar
Yah check your terminals and your ground. Does it happen after going over a bump?
Old Mar 28, 2008 | 08:46 PM
KillerBee's Avatar
Yeah did you check the ground on the battery? You have one on the alternator and the starter also those can possibly cause a shortage.
Old Mar 28, 2008 | 08:56 PM
blu3_v1p3r's Avatar
sounds like mice chewing wires
Old Mar 28, 2008 | 09:09 PM
biniecki's Avatar
Well I don't know about mice but come to think of it I saw rabbit tracks around my car and it is orange, maybe they think my car is a giant carrot lol
Old Mar 28, 2008 | 09:13 PM
BLK SS/SC's Avatar
that would deff be a big ass carrot
Old Mar 28, 2008 | 09:31 PM
KillerBee's Avatar
Old Mar 31, 2008 | 11:47 AM
MagCobalt's Avatar
same this happend to me, and my car said something about power steering. I drove for 40 min not knowing my speed. I think my rpm was working but can't remember. I got to my girls house. then when we left it was all good, had power steering back. And it has never happend since.
one other time i did a little burnout, nothing big. And my e-brake and abs lights came on. I was told because of the tires spinning. I dunno. Turned car off back on, and it was all good. MAGIC BALT. lol
Old Mar 31, 2008 | 12:37 PM
lil_kano's Avatar
check the 2nd fuse panel on the center console under the glove box. u'll see the sign for it.
Old Mar 31, 2008 | 03:14 PM
spree0708's Avatar
to me it sounds like a short which are bitches to find.
my first car the gauges used to randdomly pin, and dance so i replaced the headlight switch, relays and ultimately it was a short so i just had to keep messing with it until i got it.
it could also be a faulty sensor or ground. but like the other guy said, id prob only look to that if your car did it when you went over bumps.
if you say your fuses are good then idk, but i know in big trucks, maybe in cobalts the abs and lights often run off the same fuse so its odd that you say the abs and your gauge lights are messing up together.
Old Mar 31, 2008 | 10:19 PM
ChuckX182's Avatar
I had the same problem. It happened to be the Body Control Module going bad. It was just defective. I took it in 3 times before it was finally fixed. The first two times were at a different dealer, they just re-programmed it or re-flashed it. They did this twice, then took it to a different dealer after getting frustrated and that was the problem. So have them check that.
Old Apr 3, 2008 | 10:44 PM
dbalch's Avatar
my gauge lights went out and have not come back on so i am not sure what is wrong with it.
Old Apr 3, 2008 | 10:47 PM
erockxp's Avatar
I agree with gremlins, I had something like this but it was the power steering instead. Just unplug the battery and let the computer reset, hope forthe best. You never know with all of these sensors and crap.
Old Apr 4, 2008 | 07:37 AM
MagCobalt's Avatar
does that actually make the comp reset?like if you cel is on and you pull the battery then wait and plug back in it will go off?
will the same work if your cel is on because of a cai. Mine is going on because of that and when the cel is on my car lags huge, and engine sounds loud, and intake doesn't whine. still can go past 200km/h but it accelerates slower.
Old Apr 7, 2008 | 07:35 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Like this:
http://s138.photobucket.com/albums/q...t=20080406.flv
Mine did this to me A LOT today. I dunno what to do. All I have left on it is the Powertrain Warranty .
Old Apr 7, 2008 | 09:08 AM
ChuckX182's Avatar
It's the Body Control Module
Old Apr 7, 2008 | 09:32 AM
Did you watch my video in the post above?
Where is this BCM? How to fix/how much to replace?
$182 on GMPARTSDIRECT...
Anyone know how to replace it? And are you positive?
Old Apr 7, 2008 | 09:39 AM
3fo893013L's Avatar
mine does the same thing but my dash chimes like a light or an error happened but nothing displays as a light or error message in the DIC
Old Apr 7, 2008 | 09:40 AM
Wow... these BCM's seem to be going bad like crazy. I've read about a lot of people having this problem... and only one person has be certain and said its the BCM. Damn.
