Odd Hood Problem
Old Jun 6, 2006 | 10:46 AM
rally's Avatar
Odd Hood Problem
I've searched and not found anything about this so hopefully its new but I'm hoping i'm not the only one.
The problem is when i shut my hood yesterday it didnt look like it closed all the way..and it didnt. The driver side is still sticking up about 1/2 or so. You can look right into the engine bay! Its really weird...
I'm going to tinker with it later, but has anyone else had this happen?
Old Jun 6, 2006 | 10:52 AM
sscobalt06's Avatar
This has not happend to me, but I would check the adjustable spacer things under the hood.
Old Jun 6, 2006 | 10:58 AM
juststickit124's Avatar
Warranty!
Old Jun 6, 2006 | 02:19 PM
Rusty's Avatar
you have anything under the hood in the way? cai or maf-t? the way i had my maf-t originally installed, it was lying right under the driver's side hood shock. wouldn't close. check that stuff out first.
Old Jun 7, 2006 | 03:56 PM
thc's Avatar
thc
this happened to me. the pivet point on the hinge was overtightened. try to loosen it a little bit and see if that works.
Old Jun 7, 2006 | 06:16 PM
biohazard's Avatar
Get low
there are these rubber things that stick up on the front under your hood, rotate them and they lower or raise
Old Jun 7, 2006 | 09:19 PM
trishsher's Avatar
This happened to my Optra that I had last year!!! I put washer fluid in and when I shut the hood I thought it was closed but it wasn't and when I jumped on the highway the whole thing started to vibrate up and down. I pulled over and tried to pull on it to see if it would come up and nothing so I opened it and shut it again and it was still not latching all the way, I took it in to the dealer right away and they took the latch apart and fixed it in no time and it is all covered!!!
Hope it gets fixed real soon!!!
Old Feb 5, 2007 | 09:00 PM
Allshot's Avatar
Your a gm tech and you dont know what wrong with your car
Old Feb 5, 2007 | 09:02 PM
g5mike's Avatar
obviously a newb tech he is
rally's Avatar
Actually the body shop is seperate of the dealership, But I still get them to work on it
turbochargedss2012
Sep 20, 2023 12:17 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
