Odd noise from the front
Old Feb 24, 2011 | 11:06 PM
crazydude's Avatar
Question Odd noise from the front
When it is around -20C (cold) my 09 ls makes some off sounds as i hit bumps in the road. Small bumps dont make the sound....but bigger then normal bumps do. or even just dips in the highway. Basically, anything that makes the suspension travel alot.
The sound can best be described as rubber being rubbed against metal. It makes the sound on both the up and down motion.
Any idea what this would be? I still have warranty....but it is never cold when my appointment rolls around, so they cant replicate the sound to know what to fix.
I am guessing the shock absorbers?
Old Feb 24, 2011 | 11:09 PM
07BoostedG5's Avatar
Control arms bushings
Old Feb 24, 2011 | 11:10 PM
just replaced mine
new vs. old
Old Feb 24, 2011 | 11:11 PM
Ch1ck3n's Avatar
MY 09 ss does it as well. Only when its real cold though, and once the car's moved a bit the noise will stop.
Guess I should have em take a look before the warranty's up
Old Feb 25, 2011 | 02:21 PM
DaBuzzard's Avatar
It's the front sway bar binding in the bushings. Makes a lovely groaning noise that reverberates through the whole car.
Might be able to lube them (pretty sure that's what the dealer does) but I just put up with it for the times it gets that cold. Might get under there someday but not until it warms up - was -40* with the wind chill this am......
Old Feb 25, 2011 | 02:45 PM
kikal8's Avatar
when cars r cold they make scary noises. not to say ignore it but most of the time cars will make strange noises when warming up still. like bumps make my suspension speak and pop over the first few bumps then it goes away. same with the brakes. they may sqeal first until uses a little. again, i wouldnt ignore these noises. if you have warrenty. **** it. go get your car checked out. its free ha but i hope u get my point.
Old Feb 25, 2011 | 09:51 PM
Malaclypse's Avatar
If the noise only happens when its really cold out... I wouldn't worry about the noise. Replacing components likely will not get rid of the noise.
Old Feb 25, 2011 | 10:16 PM
crazydude's Avatar
it is a 2009 with 27k kms on it (16k miles).
Could the control arm bushings really have worn out this quickly?
perhaps it is just the way the part reacts to cold regardless of age?
Old Feb 25, 2011 | 10:33 PM
Malaclypse's Avatar
My SS/TC makes the same noise. It has all winter and has 8k on the clock.
My SS/NA made the same noise from when I bought it until its untimely end.
Old Feb 26, 2011 | 12:04 AM
My car has 35k and they went out, its a design flaw, having those cutouts in the bushing, Most likely meant for a softer ride, but the solid ones make the car feel more solid then mushy.
Old Feb 27, 2011 | 12:31 PM
crazydude's Avatar
are they hard to replace? I will perhaps track down a solid bushing and replace it.
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
