Oil consumption - Where is it going?
Old Jul 20, 2016 | 05:29 PM
jdbaugh1's Avatar
Let me start by saying I have never noticed my car to consume oil even after supercharging it and installing forged rods and pistons. I did gap my piston rings towards the higher end but after rebuilding my engine I still never noticed the oil level drop. The last work I did on it before noticing the oil burn was:
-Installed a new OEM timing chain kit from CED
-Installed Powell's trap door oil pan
-Installed LSJ belt driven components to swap to 6 rib belt
-Installed a catch can
-Installed two 3 gph meth nozzles in place of a single 5 gph nozzle. I also turned my progressive controller down all the way so that it starts to spray when I barely get into boost to prevent tip in spark knock. I no longer have a problem with tip in knock but I do burn rich in the lower RPMs (around 10 AFR)
-Started autocrossing
After I made all these final changes to my car I also started autocrossing at the same time. I don't seem to consistently use oil with milage but I definitely use oil
when I do autocross. I'm down about 1/4 of a quart after a day of autocross. I don't see any blue-grey-white smoke out of my tailpipe ever (even took some footage with the gopro to see) and I don't have any leaks. Anyone have any idea what the hell could be going on?
Old Jul 20, 2016 | 06:06 PM
blueLNFftw's Avatar
Coolant or in that catch can.
Old Jul 20, 2016 | 06:29 PM
ItalianJoe1's Avatar
It's normal to consume some oil when in racing conditions, but in a short stint like autocross it shouldn't be that bad. I'd guess it's ending up in the catch can, possibly being tossed around during the run is causing more of it to leave the engine into the PCV system which now holds it rather than returning it to the engine as stock.
Old Jul 20, 2016 | 07:00 PM
exninja's Avatar
Bet dollars to donuts catch can:
Originally Posted by Wangspeed
This is from a single track day. I emptied it after each session. I'm going to pull my valve cover off soon to see if I have a broken lash adjuster, which is causing additional issues.
20 ounce drink bottle.
Old Jul 20, 2016 | 08:30 PM
How many miles on the engine?
Old Jul 20, 2016 | 08:52 PM
jdbaugh1's Avatar
Just broke 100,000. Fresh rods, pistons, and con rod bearings.
Didn't have much oil in my catch can so I don't think it's going there.
Old Jul 20, 2016 | 09:01 PM
So how many miles on the new engine... -_-
Old Jul 20, 2016 | 09:18 PM
jdbaugh1's Avatar
lol well not everything is new but probably around 12,000 to 15,000 miles on new internal parts.
Old Jul 20, 2016 | 10:10 PM
Damn you drive a lot
Old Jul 21, 2016 | 07:56 AM
jdbaugh1's Avatar
It's my daily and I've been driving to autocross events 200 to 350 miles away.
Old Jul 21, 2016 | 09:35 AM
blueLNFftw's Avatar
I hope you have AAA and some money to two if you are driving that far to race.
Old Jul 21, 2016 | 01:12 PM
jdbaugh1's Avatar
Yeah I need a decent back-up plan but I didn't want to jinx myself planning for failure. Now that you have jinxed me anyway I suppose I better get on that.
Old Jul 21, 2016 | 01:42 PM
cluelessk's Avatar
It's only autocross. Decent tires and proper pressures is all you need and you'll make it home.
Autocross isn't really that hard on a car.
Old Jul 21, 2016 | 06:18 PM
user 72239's Avatar
Forged pistons don't run as tight a PTW clearance as well as OEM ones do so you will have some blowby no matter what
Old Aug 4, 2016 | 10:23 AM
jdbaugh1's Avatar
You can see a little oil dirt on and around the sensor.
Area noticing wetter oil/dirt
It looks like I have definitely got a leak but the question is how sever and where is it coming from. I started noticing the oil loss after I replaced the timing chain which involves taking of the valve cover. I replaced the valve cover gasket while I was at it. Don't know if this leak has anything to do with the valve cover gasket but thought i would mention the variables.
Old Aug 4, 2016 | 11:01 AM
Clean it off really well and then check it every few days to find the source
bubba_jay
Mar 1, 2016 05:18 PM
yeti as3
Feb 23, 2016 10:14 AM
rocco11189
Feb 23, 2016 07:23 AM
Jay P.
Feb 23, 2016 12:45 AM
Deej
Feb 6, 2016 08:59 AM
