Oil Drain Plug Broke!!!
What a fine representation of the Pennsylvania public school system.
You were bothered enough to write an emasculating post, but lack the attention to thoroughly comprehend the subject.
You sir, are a disgrace.
OP congrats on getting out cheap, do your own oil changes!
On a side note... I went to school in PA only for high school.
My friend in Canada works for Nissan and he said he's seen mechanics use impact guns to tighten oil drain plugs. That's how some of these places do those 15 minute oil changes...you've probably saved 5 minutes just by using a gun to take the plug off and put it back on. Derp.
I never understood why people put oil filters and drain plugs in so freaking tight. You are going to have to change it eventually. I had a oil filter that was put on so tight by the previous owner, I had to literally beat a flat screw driver through it, and two hand twist it off. Snug is all it needs.
Some people think tighter is better. Not always the case
All it has to do is be tight enough not to leak. on cars with actual oil filters not like the balt, I hand tighten them. What I have learned is generally with oil filters, the heat will actually make them tighten more with time. Oil drain plug snug, oil filter hand tight. Start the car up, check for leaks, boom, done and I know next time I can get it off.
I deal with the same thing at work. I'm an Aviation Mechanic and I have to pull out all sorts of bolts and screws that someone else put in with all they had and then some. If I could have used the tools i have at work on my car I wouldn't have had to take to it to the shop.
which hole though? There's always one more to try
Yeah you literally can torque an oil drain plug with 1 finger using a small hand ratchet. If you do strip threads a 1 time use rubber temp plug can be put it for like 1$. Just have to buy a new rubber plug every change.
I have stripped an aluminum pan before but covered the fix out of my paycheck I felt so bad. My 3rd job in life and this was right after highschool, once you learn the few tricks oil changes are easy peasy and decent money for a kid outta high school. Also got commission for every additional item sold too.
Oh yeah watch the guy doing your oil change cause my partner would skip steps if the customer wasn't watching. Far and few people will give you what you paid for. Don't feel bad for watching/talking to the guy you should have some confidence in the chap doing your cars blood work.
there are specific torque values for most structural bolts, but they really are lower then you would think they are.... the screws that hold on exterior skin panels to the aircraft are put in at 6 inch pounds....
agentirons
Oct 16, 2015 02:11 AM
