oil filter caved in?
Old Apr 29, 2011 | 02:39 PM
cmcphi1195's Avatar
so i recently changed my oil about 2 weeks ago. when i popped out the filter, it was caved in in the middle. like it was trying to be twisted. well, i threw another one in to see if it happened again and sure enough when i checked it today, BAM. it did the same thing. any idea on what would cause this? is it just crappy filters? or anything else possible.
Old Apr 29, 2011 | 02:50 PM
68nova200's Avatar
Stick with acdelco filters and this will not happen. I assume you are using the cheap walmart ones because the same thing happened to me.
Old Apr 29, 2011 | 02:52 PM
Supercharged Guy's Avatar
I would assume that you are using crappy filters, I'd stick with ACdelco or Mobil 1
Old Apr 29, 2011 | 02:54 PM
cmcphi1195's Avatar
i got the fram from autozone for the second filter. i dont remember what the first one was.
Old Apr 29, 2011 | 02:57 PM
68nova200's Avatar
get the acdelco. i have gone 5k on them and never collapsed.
Old Apr 29, 2011 | 02:58 PM
Oh, I haven't used that filter so I really can't tell you how good it is but you obviously didn't have good luck with it
So I think I'll stay away from that filter
Old Apr 29, 2011 | 03:01 PM
68nova200's Avatar
the acdelco is only a few dollars more and in my opinion shouldnt skimp out on filters.
Old Apr 29, 2011 | 03:07 PM
ecotecturbo's Avatar
Fram<acdelco
Old Apr 29, 2011 | 03:17 PM
olivecj's Avatar
The best filters for these cars are acdelco and the napa gold/wix filters. Anything else and your taking a chance.
Old Apr 29, 2011 | 03:26 PM
keiserX13's Avatar
ad that same thing happen to me a few times
been using Fram Tough guard Filter
might have to try acdelco next time, where do you get those?
Old Apr 29, 2011 | 03:28 PM
68nova200's Avatar
Pretty much any parts store by me. pepboys, autozone, napa, even walmart has them
Old Apr 29, 2011 | 03:31 PM
MoJoJoSSsc03's Avatar
i been using the purolator PUREone from advanced auto parts.. usually theyre on sale w/ synthetic oil so thats wat i stick w/.. ran 8k on my last one and looked good comin out soooo... ya..
Old Apr 29, 2011 | 04:30 PM
noblite's Avatar
The acdelco is the same filter as the STP from autozone the Super Tech from walmart and very close to the Mobil 1 oil filter without being for the long change intervals. All of the filters I listed are made one the same line in York, SC.
Old Apr 29, 2011 | 04:42 PM
06cobalt racer's Avatar
yeah i like acdelco. change mine at about 8k and no caving at all
Old Apr 30, 2011 | 02:31 AM
cmcphi1195's Avatar
so acdelco it is then. ill be picking it up in the morning then and ill let everyone know if it happens again.
Old Apr 30, 2011 | 02:32 AM
futuressturbopurchas's Avatar
A) wrong filter. B) the bypass hole is not functioning. C) if a used vehicle, possible some one replaced the oil pump with a high volume or high pressure pump to hide something.
Old Apr 30, 2011 | 02:36 AM
cmcphi1195's Avatar
a) its been the right one. b) possibility. never heard of the problem though. c) bought it brand new
Old Apr 30, 2011 | 05:07 AM
lol nice. yeah just use an acdelco one and you should be fine
Old Apr 30, 2011 | 07:36 AM
C_A_D88's Avatar
Any filter I have ever used has done thia
Old May 3, 2011 | 05:57 PM
MyOtherSS's Avatar
You need to snap the filter into the cap and then install it as one unit. If you just throw the filter in then tighten the cap chances are its not seating or snapping into the cap correctly and crushing it. I had this happen on a Delco and a Wix both quality filters before I figured it out.
Old May 3, 2011 | 06:05 PM
@nt1ric3-420$$'s Avatar
never go wrong w OEM, cus if u do, its on THEM. but, K&N is a nice piece=no problems. I had a collapse 1ce, ns exactly which might've been fram...on top of the fact oiling problem causes catastrophic failure, it also scratches things, and in my opinion just as bad, its also causes management problems pcm looks @ oil press for various thngs...
Old May 3, 2011 | 10:03 PM
C_A_D88's Avatar
I do this everyone but everytime I go to change the oil the filter looks like it has been twisted and crushed a bit, tried the mobil1 the fram the ac delco, all have done this
Old May 3, 2011 | 11:46 PM
BackInBlack's Avatar
WIX cavs every time.
If you compare any media type filter to the AC Delco, after and before using on these cars specifically, you will notice quite a few differences. AC Delco is the only one that doesn't cav, and it's also the only one with proper inner holes and chambers.
The oil filter wrinkled like that, is really nothing more than the weight of the oil it's absorbed, in combination with heat. But just stick with the AC Delco.
Old May 3, 2011 | 11:48 PM
cmcphi1195's Avatar
yea im getting an acdelco tomorrow. my cel came on and i dont know if its from the catless dp or the oil filter. so ill have to get that checked too
Old May 4, 2011 | 06:50 AM
MyOtherSS's Avatar
never had one crush on me since i started snapping it into the cap, maybe just a bad design from gm.
