Oil Spotting below head on TC
Old Mar 27, 2011 | 12:06 AM
ronn's Avatar
Noticed slight oil spotting on the head/block interface...it's not coolant.
Behind fuel pump area:
Farther back on the rear side.. from above:
Any thoughts? It's not flowing..just spotting. Car has 20K mi.
Reference:
Old Mar 27, 2011 | 12:25 AM
gotboost?17's Avatar
Nothin Stock
in for results...i have some around the 2 ports by the spark plugs
Old Mar 27, 2011 | 01:14 AM
ronn's Avatar
Found problem...Cam Cap seal TSB:
Chevy HHR Network - View Single Post - Official TSB and Recall Thread
Pip4739
#PIP4739: Oil Leak In High Pressure Fuel pump Area 2007-10 Ecotec (RPO LNF) - (Nov 9, 2009)
Subject: Oil Leak in High Pressure Fuel Pump Area 2007-10 Ecotec (RPO-LNF)
Models: 2008-2010 Chevrolet Cobalt SS Only
2008-2010 Chevrolet HHR SS Only
2007-2010 Pontiac Solstice GXP
2007-2010 Saturn Sky Redline
With 2.0L Engine RPO LNF Only
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A technician may comment of an oil leak in the high pressure fuel pump area.
Recommendation/Instructions:
Engineering has determined that an oil leak in this area is most likely coming from the #6 intake cam cap at the high pressure fuel pump. To repair this concern the technician should reseal the cam cap. Follow eSI procedure under "Engine | Engine Mechanical - 2.0L | Repair Instructions - On Vehicle | Intake Camshaft and Valve Lifter Replacement " for repair instructions and specific locations to apply sealer for the #6 cap
Thread with fix:
https://www.cobaltss.net/forums/how-...-leaks-189081/
Old Mar 27, 2011 | 01:33 PM
Nothin Stock
i dont have any in this spot that i can c, but i do have some here
Old Mar 27, 2011 | 02:46 PM
HHRSSouth's Avatar
Pip4739
Condition/Concern:
Thread with fix:
Yep, had mine fixed on my HHR SS under warranty when it was stock.
Old Mar 27, 2011 | 02:59 PM
Nothin Stock
do u guys have it where i posted my pic?
Old Mar 27, 2011 | 03:02 PM
BlackLsCoupe's Avatar
dealer told me this is normal maby someone spilled oil while filling during oil change.
Old Mar 27, 2011 | 03:06 PM
kplaya186's Avatar
x2
Old Mar 27, 2011 | 03:10 PM
HHRSSouth's Avatar
My leak was where Ronn first pic shows.
Got boost, that area is dry on my car.
Old Mar 27, 2011 | 03:14 PM
Nothin Stock
hmm ill clean it c what happens... thnx
Old Mar 27, 2011 | 03:53 PM
ronn's Avatar
Absolutely NOT that!
Read this link:
Old Mar 27, 2011 | 03:58 PM
ronn's Avatar
I don't think there is any seal in that area? It's not the valve cover area.
Doesn't look like much of anything.
Old Mar 27, 2011 | 04:02 PM
Read this link:
holy crap, i have no time for that. lol i do my own oil changes and use my funel with to bases old oil cap extender. so i know its a leak.
Old Oct 30, 2011 | 04:40 PM
RomeDiggy's Avatar
I just had my dealer fix that leak under warranty and when I got it back they did a shitty job of cleaning up oil that ran down to the bottom of the motor. I had to use 2 cans of brake clean to clean it up. At least the leak is fixed. Oh and they test drove it for 44 miles too.
06MetallicBalt
Jul 20, 2025 08:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
Trav3480
Oct 1, 2015 08:17 PM
Sep 28, 2015 12:51 PM
