Oil usage/ oil leak problems
Old 07-21-2014, 01:38 PM
lnhetzner's Avatar
My 06' SS/SC with CAI and catback, has been using oil for some time now. I've figured it to be about 1/2 quart every 500 mi the only noticeable leak I've found is near the timing cover but it doesn't leak enough to make puddles or leave copious amounts of oil everywhere. Blow by is pretty normal. Does not seem excessive. Plugs all came out clean. Any thoughts??
Last edited by Staged07SS; 07-21-2014 at 02:33 PM. Reason: It's not stock if it has a cold air intake and catback....
Old 07-21-2014, 01:58 PM
footballplaya3k's Avatar
How many miles? Have you done a compression test?
Old 07-21-2014, 02:27 PM
lnhetzner's Avatar
Just over 80k and no sir. I really need to to compression and a leak down. Don't have equipment for either though.
Old 07-21-2014, 02:46 PM
lnhetzner's Avatar
Old 07-21-2014, 03:11 PM
Sl0wbaltSS's Avatar
Your cylinders are going out and or something is leaking it into the blow by ALOT. My last car did that and went through like 7-8 quarts before an oil change!
Old 07-21-2014, 08:54 PM
Have you checked the plugs to see if they're wet after a drive?
Old 07-21-2014, 11:01 PM
lnhetzner's Avatar
Yes. I stated in my initial post that I checked the plugs and the intake for blow by. Appreciate the input fellas
biniecki
10-25-2015 02:23 PM
brandon04
10-21-2015 07:04 AM
717ssbalt
10-02-2015 04:01 PM
Trav3480
10-01-2015 08:17 PM
Adiaz1ss
09-26-2015 11:51 PM
Quick Reply: Oil usage/ oil leak problems
