Ok peopleeee
Ok peopleeee
ok I just bought a 2006 cobalt ss and I noticed that when I turn the key over I don't have a check engine light indicator and my car got to 225 degreese when I was in bad traffic the other day and the fans did not kick on can someone shed some light on this the car doesn't get hot if im driving it just at a stand still and I cant find the mass air flow sensor I have a k&n intake pipe I for got the name off the top of my head but I looked everywhere and there nothing but drives good
correction it a typhoon intake by k&n
pull your gauge cluster and check behind the panel for this...
previous owners of my car decided to block off the check engine light to hide the 13 codes on the computer. There are two fuses under the hood in the fuse block for the fan, both fuses have to be good for the fans to operate correctly. The MAF is on the drivers side lower on the intake pipe closer to the fender well.
Punctuation. Use it.
From what I can decipher, you're asking like 3 different things.
Your check engine light should be over to the left, near the speedo. Directly to the left of the ebrake light.
225 isn't that hot for these cars while sitting in traffic. Fans kick on at 230, if I recall right. If you're really concerned that can be changed with a custom tune using HPTuners.
The intake has a MAF sensor. It's down near the bottom by the filter.
I apologize Ill check agiain but I couldent see anything lol
ill check the fuses or the fan I was actualy expeting this car to be 100 percent functional lol but that's never the case
that picture didn't up load so can we get a retry lol
ill check when I drive its always at 185 183 im not really worried or should I be ya so far my car luck is shitty I always get cars that people mess with and then sell and I happen to be the buyer
ya I really hope this car lasts im about to be leave the state for work and don't wana get stranded, and what radiator fluid is pinkish it would be simpile to go to autozone and ask but is it a certain type I was told its a non crosive pinkis color cuz the radiator is alluinum
ok the dash is pretty solid hopefully i don't break it doing it now i don't think i need any tools mabe a flat bar hmm lol
( this isn't a job site requirement is it) lmao jk
