One headlight is very dim
Old Apr 27, 2016 | 01:50 PM
Dougsterbob's Avatar
i think I saw someone else with this problem somewhere, but I was driving last night and I noticed a headlight out (that's how dim it is) so I put in a new bulb, and that's when I noticed that there is still a bit of light coming from it. After that I threw in the old one and saw the same thing.
I bought the car after it had been sitting for a while, and I've only had it a few days.
Thanks in advance!
Old Apr 27, 2016 | 05:36 PM
LsCobalt07's Avatar
Check the connectors. I had the same issue and the connector was melting because the contacts were worn.
Old Apr 27, 2016 | 05:39 PM
Where the bulb connects? Or where the unit connects about a foot back along the wiring?
Old Apr 28, 2016 | 12:21 AM
cobaltss#01's Avatar
check both. it can't hurt.
Old Apr 28, 2016 | 07:23 PM
So where the whole headlight unit plugs in, I noticed that if I wiggle it the light starts working right again.
I detached them and on one prong the plastic had melted so I assume it wasn't getting a good connection. The plug had a gob of electrical tape around it, so I assume this isn't the first time this happened
Anyway the replacement part is like $40 and that seems kinda crazy for a piece of plastic so I just cleaned it up with a wire brush and tried to do a better tape job then the last guy. Now the lights work but when the lights are on, that sides blinker doesn't work, but when the lights are off the blinker light does work. ( it's slightly dinner then the passenger side ) I'm not sure if this is now a bad connection there too, or if the bulb is just worn out and needs replaced.
Old May 2, 2016 | 12:12 PM
Northindy's Avatar
I had a similar problem. Tried to clean up the connectors, etc., but it never would make a good connection, and the plastic bulb retainers are easy to break. Replaced the wire harness (3 bulbs), and it now works great.
red s s
18
Aug 24, 2016 06:26 PM
Tykuura
Jul 31, 2016 02:39 AM
Stu_x24x
Apr 25, 2016 10:18 AM
ballsup
Apr 7, 2016 09:52 PM
slowski06
Apr 6, 2016 01:40 AM
