One Lighter Not Working
Old May 22, 2013 | 08:27 PM
JshLnsctt's Avatar
My top lighter socket is not working, though my lower one is. I replaced the entire socket and checked that the cables looked okay going into it, though don't see any issues. Both sockets appear to be on the same fuse, so I doubt that is my issue. Any suggestions of what to look for or what to check?
Old May 22, 2013 | 08:35 PM
That is weird if both are on the same fuse and one works and the other doesn't
Old May 22, 2013 | 08:55 PM
gotboost?17's Avatar
Nothin Stock
i have a extra one, pm a offer
Old May 22, 2013 | 08:56 PM
Nothin Stock
u can swap them an c if the problem follows
Old May 23, 2013 | 01:57 AM
hizzo3's Avatar
I ran into the same problem about a month ago. Top one quit working when running an air compressor (using it to set the bead on motorcycle tires). I haven't had a chance to chase it down yet.
Old May 23, 2013 | 12:23 PM
JshLnsctt's Avatar
I have already tried replacing the entire socket, though there is still no power
Old May 23, 2013 | 01:19 PM
coolbalt1's Avatar
Same happened to me I changed the fuse and it did the trick
Old May 23, 2013 | 07:43 PM
JshLnsctt's Avatar
You had only one working? Which fuse did you change? Cig under hood?
Old May 24, 2013 | 01:33 AM
hizzo3's Avatar
Just fixed mine. Engine bay fuse box. It was one of the 15amps that blew.
Old Feb 7, 2016 | 05:58 PM
jaydd73's Avatar
FYI the two sockets are on different fuses.....
Old Feb 7, 2016 | 05:59 PM
jaydd73's Avatar
I however have run into.....top working, bottom is not, but trunk light works and no blown fuses under the hood
-_-
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
jmelton327
Sep 26, 2015 10:04 PM
