p0017
Old Mar 4, 2013 | 09:41 PM
kjgcobaltss's Avatar
p0017
Alright heres the thing. Got my zzp stage 2 cams in (comp) and i know i got my timing right because i raninto this problem before. And i got the cam position sensor in the right spot just wondering if anyone has had the p0017 code come up after installing the stage 2 cams. Im wondering if maybe the part where the cam position sensor goes into the cam is slightly in the wrong position. ? Maybe im wrong idk but any help would be nice. Thanks
Old Apr 25, 2016 | 10:15 PM
315SS's Avatar
I am having same issue after istall of zzp stage 2 cams and 82# valve springs. I removed front cover set the timing and also installed a new cps prior to turning the car over. ran at idle great for about 20 seconds then stalled and now will keep turning without firing also the code p0017 came up on my scan gauge. any advce from someone this has happened to is appreciated thanks. -kevin
D_Elite
Aug 12, 2014 12:44 PM
rukkee
Jul 9, 2010 05:55 PM
rukkee
Oct 3, 2009 01:56 AM
rukkee
Sep 21, 2009 06:47 PM
*TRIX*
May 24, 2008 01:01 PM
