P0036 lsj
Old Feb 4, 2011 | 12:33 AM
PenguinPIE's Avatar
P0036 lsj
I've been getting the P0036 code without any CEL. I've searched several threads but I still couldn't find out what's causing it. Any help would be appreciated.
I have read that it may be a bad sensor or a blown fuse due to a short somewhere.. I have no idea which sensor or which wire to check tho.
Old Feb 4, 2011 | 12:40 AM
D_sean257's Avatar
is the car missing?
Old Feb 4, 2011 | 12:41 AM
PenguinPIE's Avatar
yup, it is misfiring usually between shifts. it shows about 20 when the engine is cold, a bit less when it is warmed up.
Old Feb 4, 2011 | 12:44 AM
RooTBeeR's Avatar
get new spark plugs?
Old Feb 4, 2011 | 12:45 AM
D_sean257's Avatar
https://www.cobaltss.net/forums/prob...-inside-93655/
hope this helps. Let me know if it does or not. I will be up awhile I can help research some more lol
Old Feb 4, 2011 | 12:49 AM
PenguinPIE's Avatar
the spark plugs are new and they were gapped at 0.035, NGK BKR7EIX
I'm currently running GMS3 Tune with 76mm (2.99") pulley
The exhaust is all stock
Old Feb 4, 2011 | 12:50 AM
RooTBeeR's Avatar
lol guess i shoulda looked at what the code was first
PenguinPIE's Avatar
thanks, I saw this thread before but i have no idea which sensor/fuse/wire to check for shorts...
Old Feb 4, 2011 | 12:53 AM
D_sean257's Avatar
check the ems fuse under the hood
Last edited by D_sean257; Feb 4, 2011 at 12:54 AM. Reason: should say wich one it is on the fuse cover.
Old Feb 4, 2011 | 12:56 AM
PenguinPIE's Avatar
ah so it is ems, I will check that tomorrow
so I'm guessing the misfire isn't the cause of this code?
Old Feb 4, 2011 | 12:58 AM
D_sean257's Avatar
well according to what I have read, the fuse being blown is causing the misfire and the misfire is causing the code.. Could be wrong, but it is worth a look atleast lol.
Old Feb 4, 2011 | 12:59 AM
PenguinPIE's Avatar
haha that's interesting. I will check tomorrow and hopefully it is the fuse
thanks so much for the help! i will update tomorrow
Old Feb 4, 2011 | 01:02 AM
D_sean257's Avatar
If the fuse is blown then it is a short from the 02 wire on the cat.. so if its blown, check out the wires coming from that, they should be damaged.. if they fuse is good. Id still check the wires.. other than that.. I have no idea lol, Ill look some more. gl
Old Feb 4, 2011 | 01:18 PM
PenguinPIE's Avatar
The fuse is fine and checked with a multimeter. I was really hoping the fuse was blown lol...
Old Feb 4, 2011 | 10:40 PM
D_sean257's Avatar
wb the wires from the 02? good?
Old Feb 6, 2011 | 01:46 AM
PenguinPIE's Avatar
i dont have anything to jack up the car and i cant really see anything from the top...
i will find a way to check the wires i guess =/
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
ThoR294
Oct 4, 2015 08:44 PM
Sep 28, 2015 12:51 PM
