P0107 - Map Dtc
Old Jun 28, 2006 | 11:39 PM
Doc's Avatar
Doc
P0107 - Map Dtc
This is the code that keeps coming up when I scan with HPTuners.
P0107 - Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage (SES) (Pending) (Old) (History) (Current) (Immature)
I also noticed that it doesn't log the MAP in the scanner either.
This car had the Rev-it-up kit on it and we recently removed it. Actually, snipped the wires.
Has anyone experienced this DTC before?
If you have, whats the fix?
Thanks
Old Jun 29, 2006 | 12:00 AM
06blackg85ss's Avatar
probably has something to do with the wires... check you connections and maje sure nothing is shorting on it.... NO ELECTRICAL TAPE... get some good connectors for it
Old Jun 29, 2006 | 12:05 AM
Doc's Avatar
Doc
Makes sense since the RIU kit masks the boost, which I believe is controlled by the MAP.
Old Jun 29, 2006 | 12:07 AM
patathSS's Avatar
Yeah mine logs the MAP fine, check those wires.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
Dustonian131
Sep 23, 2015 08:03 PM
