P0300 help
P0300 help
hey guys im new here and bought a 07 supercharged gm stage 2 a couple weeks ago. when i bought the car it had no check engine light but a couple days after the code P0300 popped up.. it was also getting like 14mpg!! changed spark plugs and fuel filter and mpgs went up to about 22 and check engine light went away. after a couple more starts it came back on.. the car has a really loud exhaust leak do you think it could be causing the random misfire? only thing out of the ordinary with the car is that when im at a stop and rev the engine it hesitates alittle bit.
alright guys here's an update.. replaced plugs with stock copper ngks gaped at .35, fixed exhaust leak, cleaned throttle body, replaced a bad intercooler pump, changed oil and it smelled like fuel, held a screwdriver up to each fuel injector and each of them are ticking. code came back on. here is the freeze frame data on my free obd software.. lol.
P0300
Fuel system 1 status closed loop control using oxygen sensor - normal
Calculated load 25.9%
Coolant temperature 69 deg C 156.2 deg F
Short term fuel trim bank 1 3.91% Lean (-)
Long term fuel trim bank 1 1.56% rich (+)
Intake manifold pressure 41 kPaA 5.9 PsiA
Engine speed 766.25 Rpm
Vehicle speed 0 Kmh 0 Mph
Ignition timing advance cyl #1 11 Degrees Advance (+)
Intake air temperature 10 Deg C 50 Deg F
Mass air flow 3.92 g/s 0.5 lb/min
i dont know if this data helps but what do you think it could be?
P0300
CobaltSS_25
Nov 17, 2009 05:20 PM
