p0420
Old Mar 25, 2009 | 07:55 PM
OiangeSS's Avatar
p0420
this is a code for cat converter efficency has anyone else got this code? i have nothing but a sts and intake
thanks
O!ange
Old Mar 25, 2009 | 08:14 PM
1niceLS's Avatar
I think thats the code for running to lean you probably threw it after installing the intake its common just check for leaks
Old Mar 25, 2009 | 08:36 PM
TRANSAM197781's Avatar
no it sounds like youre cats gone
Old Mar 25, 2009 | 09:54 PM
YellowRocketSS's Avatar
You need a cat. Cat is going byebye
Old Mar 25, 2009 | 10:16 PM
OiangeSS's Avatar
yea the dealer said moisture geting through the k&n but i called bs and the last time i took it to them they said i needed a cat which i already knew but they wont listen to me but anyways instead of replacing it with OEM they bought one from napa welded it on and didnt warranty it they internaled it to themselves
Old Mar 25, 2009 | 10:36 PM
efrommel's Avatar
Is this code from having a high flow cat??? I have a 1 3/4 header with the d/p with high flow
Old Mar 25, 2009 | 10:40 PM
zrated89's Avatar
if you have this code you cat is gone and for the dealer welding in a cat thats BS they subcontract their weld jobs out to people like midas or meineke we used to do their work they need to put a new downpipe in for you end of story i would have never accepted that
orange yes you will have it from a highflow as well because your downstream o2 sensor isnt seeing what it wants have someone with HPT disable the code so it wont set ur CEL
Old Mar 25, 2009 | 11:21 PM
OiangeSS's Avatar
no highflow cat jus stock and im taking it back tomorrow i have already contacted the general manager about it
SSinPA
Jul 9, 2010 08:56 AM
SprChrg4Life
Jun 20, 2010 03:15 PM
XgunsmokeX
Aug 15, 2009 03:52 PM
jpunishment
Dec 11, 2007 10:48 PM
rollingboostedss
Jan 24, 2007 11:52 PM
