P0480- Rad fan on all the time
Old 03-07-2007, 04:15 PM
b-spot's Avatar
Anyone throw a P0480 here yet? I had that, among 7 other codes, and the rad fan is now on all the time when the car is on, which makes sense given the code. The only problem is the dealer can't seem to figure out how to fix it. They just cleared the codes and gave it back to me. They tried to charge me $115 labor saying that this way they wouldn't have to tell GM about my intake.
I told them to eat me and they can tell GM all they want about my intake since it has nothing to do with the problem.
Old 08-14-2008, 09:07 PM
Scoot05RedSS's Avatar
Ok so he got no reply but I'm having the same code. My fan is on all the time as long as the key is on. They car doesn't even have to be running. I have no other codes, I've attempted to change the relay, but it does the same thing with the new one. I can't seem to figure it out. And the 3 GM service techs I've talked to can't either, they just wanna run a diagnostic on my car and I'm too worried about them ******* up my tune. Plus I don't wanna pay all that money for the dealership to do it. I'm pretty handy with fixing ****, so if I could just figure out what's causing this, I can fix it myself. All my temps are normal and it's not having any adverse effects on my car. I'm beat!
Old 08-14-2008, 09:10 PM
brett5's Avatar
well what happened when it threw the code were you driving what happened
Old 08-14-2008, 09:13 PM
Didn't notice it till I killed the car and the fan stayed on for about 2 mins after I got out. The next time I got in it was throwing the CEL. It depends on how long I've been driving as to how long they stay on after I get out.
Old 08-14-2008, 09:14 PM
brett5's Avatar
has it been really hot out do you have any cooling mods
Old 08-14-2008, 09:16 PM
it is hot outside here in Louisiana. And yes I have cooling mods-Cobra H/E and Meth Injection.
Old 08-14-2008, 09:19 PM
brett5's Avatar
the only thing i can think of it maybe make sure your thermostat is working properly..the fan only stays on after the car shuts off if it senses temps exceeding a certian amount
Old 08-14-2008, 09:21 PM
The fan comes on instantly with the key no matter what the temp of the car is. I replaced the thermostat about 5 months ago so I don't think it's bad. Also I don't see any temp changes to signify the thermostat. I'm confused!
Old 08-14-2008, 09:25 PM
brett5's Avatar
i know one guy had this happen to him but he had someone messing around o HPtuners with what temps the fans come on at...you didn't do that did you/?? cause i have no idea
Old 08-14-2008, 09:27 PM
no it was on the same tune over a year before this happened.
Old 08-14-2008, 09:30 PM
Witt's Avatar
Check the circuit for a short to power. Probably a bad fan relay.
Old 08-14-2008, 09:32 PM
Well, I changed the relay, went to GM and paid like 30 bucks for it and it did NOTHING LOL It sucked!
Old 08-14-2008, 09:41 PM
YellowRocketSS's Avatar
try ur temp sensor... it might be reading to hot and making the fan stay on
Old 08-15-2008, 03:34 AM
theneelster's Avatar
Yeah...either that or raise the "on" temp to something higher...but then it won't come on at all...hmmm...that's a bad idea.
Old 08-15-2008, 04:41 AM
silverfae7's Avatar
The code is for the cooling fan relay 1 control circuit which means the low speed. If you already replaced the relay (hopefully the right one, you do have 3), you may have a short to ground. The bad news is that the fan 1 circuit is contolled through a solid state driver internal to the PCM. Your PCM may be shorted.
Old 08-15-2008, 09:14 AM
brett5's Avatar
ouch looks like a stage 3 pcm for you
Old 08-15-2008, 01:02 PM
Wow sounds great! What can I do to find out for sure I need a new PCM? I gave the dealership the code and they gave me the relay I needed to replace. I only tried one. Where are the other 2?
Old 08-15-2008, 04:16 PM
silverfae7's Avatar
You will need do do some pin-outs on the PCM connector for that circuit. And test for short to ground on the entire cooling fan 1 circuit. Shoot me a PM with your e-mail and I can send you the diag for it. Hopefully you can understand schematics and how to test electrical systems.
Old 08-20-2008, 01:29 PM
So any other ideas guys. I just find it hard to believe that a bad PCM would only cause my rad fan to stay on all the time. Seems like it would be a little more detrimental!
Old 09-27-2008, 04:44 PM
eckow8's Avatar
i know this thread is old but....
Where is the relay for the fan? My fan runs from the time I start my car until I turn it off (it doesnt stay on when the key is in or when the car is off like guy above). My temps are all good too, Im pretty sure its just the relay....
Old 09-29-2008, 10:41 PM
eckow8's Avatar
Alright I know I didnt get answer but...
I replaced the fan relay- only 1 though bc thats all they had in stock at the dealer I went to. And the fan still runs constantly so I went back and had them run the tech2 on it and I ended up the same code these 2 guys had- P0480. So what should I do? Replace both of them and see what happens or did anyone come up with a solution?
OH yea, there is not 3, there are 2 relays...
Old 09-30-2008, 03:24 AM
silverfae7's Avatar
Oh yeah, there are 3 relays for the cooling fans. Cool fan 1 relay, cool fan 2 relay,and cool fan s/p relay. They all have to do with the cooling fan circuit. The last one controls the 3rd speed that only the SC cars have. The P0480 has to do with the cooling fan control internal to the PCM. If you are getting this code and all of your relays are working, you either have a wiring problem (i.e. short to +/- or open) or you have a bad circuit in the PCM. Most likely the PCM.
Old 09-30-2008, 02:33 PM
eckow8's Avatar
****, so is there anything I can do about that then?
Old 10-01-2008, 03:30 PM
eckow8's Avatar
anyone???
Old 10-01-2008, 03:50 PM
zillaguy07's Avatar
I wonder if its a problem in the air conditioning side of it....fans come on whenever the A/C is on also....I dont know enough about these cars to say what does the switching for it though.
Quick Reply: P0480- Rad fan on all the time
