P1101 And P0300
Old Dec 6, 2008 | 12:10 AM
fzn14's Avatar
P1101 And P0300
P0300-Random misfire....could a clogged fuel filter do this?
P-1101-Performance intake code..MAF gone bad?
Under normal driving conditions everything is ok. But when i come to a stop and idle down that you can here it missing threw the exhaust
Old Dec 6, 2008 | 05:37 PM
fzn14's Avatar
Anyone?
Old Dec 6, 2008 | 05:40 PM
Tazmanian_Dvl's Avatar
MAF sensor. Do you have a CAI on your car?
Old Dec 6, 2008 | 09:52 PM
fzn14's Avatar
nope air box mod
Old Dec 6, 2008 | 10:00 PM
clean your MAF sensor and clear the codes if you can. If you can't drive the car for a day or two and if that's what it was it will shut off. Make sure you use MAF sensor cleaner...
that's the codes I get when my MAF sensor gets dirty...
Last edited by Tazmanian_Dvl; Dec 6, 2008 at 10:00 PM. Reason: Automerged Doublepost
Old Dec 7, 2008 | 12:50 AM
fzn14's Avatar
does it make the car misfire thow? i can kinda hear it in the exhaust..car has 31k on it and had the airbox mod since 25k....SOOO
Old Dec 7, 2008 | 11:35 AM
yep. when my car does it the car runs like total dog ****!
Old Dec 7, 2008 | 03:03 PM
fzn14's Avatar
ok well put a new fuel filter and cleaned the MAF and we will have to see what happens
Old Dec 8, 2008 | 06:44 PM
fzn14's Avatar
ok well the CEL stays off longer but still throws again...P0300 still...SOOOO
Old Dec 8, 2008 | 06:51 PM
pull your plugs you may have fouled them. They might need to be replaced or at the very least cleaned up a bit...
Old Dec 9, 2008 | 03:31 AM
fzn14's Avatar
there is no way...they got MAYBE 4k on them...BUT the car is SLOWLY coming back to org. way it was...I think things where gummed up between the filter and hit the injectors..i am running cleaner threw them and seems to be getting better and better so...
Old Dec 9, 2008 | 08:30 AM
when the MAF sensor ***** up it makes the car un like **** and probably run really rich it it runs like mine does when it happens. when you run rich you can foul the plugs and cause a miss. you can foul plugs and never move the car. the number of miles on them means nothing...
Old Dec 9, 2008 | 08:48 PM
fzn14's Avatar
well both codes threw at different times...maybe i will just get a new maf and see whats up
Old Dec 9, 2008 | 11:42 PM
I"d do plugs and the MAF sensor...plugs are like $2 each...
Old Dec 10, 2008 | 03:56 PM
fzn14's Avatar
i got iderdiums(sp)
And plus i put my stockers back in for a bit with the same results...Misfire came back
Old Dec 10, 2008 | 03:58 PM
ilovecars's Avatar
sux dude. no idea whats up with it
Old Dec 10, 2008 | 03:59 PM
is this all on the same tank of gas?
Old Dec 12, 2008 | 07:03 PM
fzn14's Avatar
Nope....MANY MANY different tanks
Old Dec 12, 2008 | 08:27 PM
Dragonsfire12345's Avatar
mine does the samething and can't figure out whats wrong with it....
Old Dec 12, 2008 | 08:42 PM
fzn14's Avatar
what solutions have you tired?
Old Dec 14, 2008 | 09:13 PM
fzn14's Avatar
? Have you put a new maf in?
Old Dec 14, 2008 | 09:39 PM
nope...Everytime it's happened to me it went away after i cleaned the MAF and cleared the code...is it possible you sucked water into the intake and got it wet?
Old Dec 14, 2008 | 10:48 PM
Cobaltss/TC's Avatar
Do you have the 2.4 motor? if so it could be under the injector bulletin, where all 4 are being replaced for leaking fuel, remember a misfire can also cause false MAF codes
Old Dec 14, 2008 | 11:00 PM
I believe he has the SS/SC
Old Dec 14, 2008 | 11:13 PM
well in that cause not sure
