P1133 ? searched
P1133 ? searched
p1133 just came up on my car. I have had p0420 for a couple months as the cat went bad and shotvout the ezhaust. I have a CA 3" header and dp for 1 year with no problems. I randomly get a random misfire code and it isn't on now. Is this a warranty claim? I am at 34850 now.
Conditions for Setting the DTC
• The PCM detects that the HO2S 1 rich-to-lean counts, or the lean-to-rich counts is less than a calibrated value.
• DTC 1133 sets within 60 seconds when the above condition is met.
Important: The HO2S 1 may be damaged due to contamination.
Yeah I read that. Reason I am asking is when I searched a few post mentioned that the header or downpipe may be the cause. I dont want to bring it in and the dealer tell it is from my intake/header/catless downpipe that I have had on for a year.
The cat blew apart two months ago. When I took the dp off 3 weeks ago to look at it nothing was left inside the cat. so maybe it damaged the o2 sensor after the cat even thought the p0420 was already set.
Delta coupe
Sep 30, 2015 08:11 AM
