p2177? 0 boost.
Old Nov 6, 2014 | 10:33 PM
c0de7477's Avatar
p2177? 0 boost.
So, little bit about what's going on. I've been having weird 0 boost issues... car will run fine, then out of nowhere, 0 boost, and maf codes. If I turn the car off then back on, it's fine. No boost leaks, checked thoroughly. So i replaced my k&n intake with the stocker and zzp tube to see if that was the issue, and the original codes went away. Now i'm getting 3 codes. 2 are p2177 (idle lean bank 1) and p0101 (maf performance).
Is this just a tuning issue because i changed the intake? I need to get rid of this POS trifecta tune, but I won't retune until i know 100% that the tune with the intake is causing the issues. Also, i installed a ZZP intercooler kit but haven't retuned for it.
I've checked for boost leaks, and my spark plugs and gap. Everything seems fine.
All input is appreciated.
Old Nov 7, 2014 | 12:30 AM
tomj77's Avatar
did u do a boost leak test or did u just look for loose tbolts or holes?
Old Nov 7, 2014 | 07:32 AM
iboost's Avatar
Like 99% of MAF codes are for a boost leak, especially if you are getting a lean code too. That means you are having unmetered air entering your system through a leak. Checking and just tightening clamps isn't going to do it. You need to do a proper pressure/boost test.
Old Nov 7, 2014 | 09:36 AM
tomj77's Avatar
See that's what I don't get, a boost leak will not bring in unmetered air because a boost leak is post turbo and the air is being pushed. I will always lose air never gain air through a boost leak, even if ur at idle the turbo is still pushing air. Like when I had a bov that was open at idle, air was coming out , non was sucking in. So how can u get unmetered air with a boost leak. Does the maf not throw the code cause it's metered air is dissapearing from the system?
Old Nov 7, 2014 | 09:45 AM
c0de7477's Avatar
Well, from my understanding, of researching last night, a lean code can usually be caused by a vacuum leak. I think this weekend I'm going to replace all my vacuum lines, they are old asf anyways.
Old Nov 7, 2014 | 09:46 AM
c0de7477's Avatar
btw iboost, nice sig. Black with Orange are the two best color combos imo.
Old Nov 7, 2014 | 01:57 PM
iboost's Avatar
Thanks!
Old Mar 21, 2016 | 01:05 AM
jpickles's Avatar
So what was the cause of this issue. I'm having the same problem with my 09 SS. I have full bolt ons except a factory bov and downpipe and I have hp tuning. It usually hits 20 - 23 psi and one day it decided to do the same as your car and make this weird jerk and then only hit 0psi. Maybe 1psi if I'm lucky haha. I took off everything and checked everything for holes, cracks, etc. (bov and such also) and I slowly put it all back together making sure it's all good. I reset my car and went for a test ride and drove good for a minute or two, then came that jerk and the 0psi Prius power. I know I checked every sensor to be plugged in and made sure there wasn't a losse connection to any hose and I made sure there wasn't a leak in my piping/intercooler. If anyone can help I will cry with happiness lol. And I'm new to this so idk how to use it or such so please forgive me.
Old Mar 21, 2016 | 03:02 PM
reybalt's Avatar
p2177? 0 boost.
Turbo Johnny
Feb 21, 2019 09:41 AM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
jcarroll53
Sep 24, 2015 07:43 PM
TylerJHowell
Sep 21, 2015 06:47 PM
reybalt
Aug 31, 2015 02:32 PM
