P2431 Anyone know how to fix it
I had my MIL light on, got it scanned and this is what came up.
Sec.Airinj.system
Air Flow/Press.sen
ckt Rng/Pref. Bank1
Went to the dealer and they said it is "Secondary Air Injection System Pressure Sensor A Circuit Range/Performance" But did not tell me how to fix it. Has anyone had this problem or know how to fix this problem? Thanks for any info that can help.
Sec.Airinj.system
Air Flow/Press.sen
ckt Rng/Pref. Bank1
Sec.Airinj.system
Air Flow/Press.sen
ckt Rng/Pref. Bank1
Sec.Airinj.system
Air Flow/Press.sen
ckt Rng/Pref. Bank1
Here is their website and I even found a trifecta authorized dealer for you. Might give them a call or get ahold of Vince from Trifecta and see if this can be turned off. Their tunes are very nice and give a nice increase in power and fuel economy. Jesus i sound like a salesman.
http://www.trifectaperformance.com/
Trifecta Tuning Shop: KRS Performance
KRS Performance
Hartford, CT
Contact: Michael Soucy sales@krsperformance.com
http://www.krsperformance.com
Specialities: GM Delta Platform (Cobalt, Ion, Pursuit)
KRS Performance
Hartford, CT
FYI
Circuit/System Description
The secondary air injection (AIR) system aids in the reduction of hydrocarbon emissions during a cold start. The system forces fresh filtered air into the exhaust stream in order to accelerate the catalyst operation. An electric air pump, the secondary AIR injection pump, provides filtered air on demand to the AIR control solenoid valve/pressure sensor assembly. The AIR control solenoid valve/pressure sensor assembly controls the flow of air from the AIR pump to the exhaust manifold. The AIR solenoid valve relay supplies the current needed to operate the AIR solenoid valve/pressure sensor assembly. A pressure sensor is used to monitor the air flow from the AIR pump. The control module supplies the internal pressure sensor with a 5-volt reference, an electrical ground, and a signal circuit.
The AIR diagnostic uses 3 phases to test the AIR system:
DTCs P0411 and P2430 run during Phase 1
DTCs P2430 and P2440 run during Phase 2
DTC P2444 runs during Phase 3
During phase 1, both the AIR pump and the solenoid valve are activated. Normal secondary air function occurs. Expected system pressure is 8-10 kPa above BARO.
During phase 2, only the AIR pump is activated. The solenoid valve is closed. Pressure sensor performance and solenoid valve deactivation are tested. Expected system pressure is 20-25 kPa above BARO.
During phase 3, neither the AIR pump nor the solenoid valve is activated. AIR pump deactivation is tested. Expected system pressure equals BARO.
In all 3 phases, testing is accomplished by comparing the measured pressure against the expected pressure. The control module can detect faults in the AIR pump, AIR solenoid valve/pressure sensor assembly, and the exhaust check valve. The pressure sensor can also detect leaks and restrictions in the secondary AIR system plumbing.
