PLEASE HElP!!!
Old Apr 18, 2009 | 01:10 AM
eman777's Avatar
PLEASE HElP!!!
so tonight i was turning out of a development onto a 45 mile an hour road and once i got straight i floored and attempted to no lift **** 1st to 2nd. well when i jabbed it into gear it didnt go. i pull over and try all my gears and figure out that only have 1st, 3rd and 5th. i lost 2nd 4th and reverse. when i would try to put it into second or forth it would just revs and there is no gear there its just like neutral. im going to take it in tomorrow to the dealer. any thoughts?
cliff notes:
1. no lift shift from 1st to 2nd
2. when i did there was no 2nd
3. 2nd. 4th. reverse dont work. 1,3,5 gears work but are different feeling.
Old Apr 18, 2009 | 01:39 AM
pookie025's Avatar
that doesnt sound good hope all goes ok il pray for you
eman777's Avatar
thanks man i need to pray to
Old Apr 18, 2009 | 01:42 AM
recklessactn's Avatar
double post
Old Apr 18, 2009 | 01:46 AM
YOUR FINE! It has happened to me, you need to pop out your cup holder and put the shifter linkage back into the bracket.
If you can't snap it back in with just the cup holder out, you need to take off the plastic molding around your e-brake, then pop up the plastic molding around your shifter. you will see two black linkages connected to your shifter. If you shift into 2nd or 4th you will see the linkage pop up. Take that linkage and press it down into the bracket. and your done.
Last edited by recklessactn; Apr 18, 2009 at 01:46 AM. Reason: Automerged Doublepost
Old Apr 18, 2009 | 01:47 AM
steddy2112's Avatar
It's either that, or you broke your roll pin which is an easy fix.
Old Apr 18, 2009 | 01:50 AM
NWAE Cobalt's Avatar
yup...what they said lol
Old Apr 18, 2009 | 01:56 AM
Acey's Avatar
Why have gears when you have a motor as torquey as the LNF. 3rd is fine for all driving situations.
Old Apr 18, 2009 | 02:26 AM
Sharkey's Avatar
im going to say its a bent shifter cable. i had the exact same thing happen when i bent the shifter cable in my cavalier at the dragstrip. i tried to powershift 2nd and it didnt go, then i had a hard time getting it in to any gear. when i got back to the pits i could get it in 1st 3rd and 5th only.
Old Apr 18, 2009 | 07:05 PM
eman777's Avatar
alright thanks guys
Old Apr 18, 2009 | 09:41 PM
Ishbar's Avatar
Sounds like linkage, but it could also be Trans.
I don't really know much about the anatomy of the Cobalt, but the same thing happened to my Saab.
Though it was first 3rd gear that didn't work, THEN I couldn't use 4th, and then if I was in 5th It wouldn't let me go back into 1st. It felt like shifting into nothing, then it stopped shifting period.
Old Apr 18, 2009 | 10:51 PM
eman777's Avatar
ya i took it in today and got a rental so wwe will see how long it takes
Old Apr 18, 2009 | 10:55 PM
auggie_ss_phx's Avatar
enjoy ur rental u will have it for weeks
Old Apr 18, 2009 | 10:59 PM
eman777's Avatar
haha got the new malibu instead of the aveo
