please help!! (ion redline)
Old Oct 24, 2014 | 09:17 AM
eatinJDM's Avatar
Hey everyone I'm having a serious issue with my redline. I bought it around a month ago and it didn't have much clutch left at all. So I bought the lsj clutch upgrade kit from crate engine depot along with a new oem flywheel, 8 New flywheel bolts and 2 quarts of the trans fluid. I put the clutch in myself by following the chapter 5 instructions in the gm build book. Everything went smooth, no issues. Once it came time to bleed it I couldn't get it to bleed. I tried every method I could find on this forum and online. After being tired if dealing with it I dropped it off at my local Aamco and they've had it for 4 days now and they can't get it to bleed either. They recommend I take it to the chevy dealership down the street and they say they NEVER recommend someone go to a dealer. Is there anything I could have messed up when putting the clutch In that would make it unbleed-able? I know the little black nipple is on the distribution block and there isn't a second one stuck, there's nothing leaking from the case or anywhere. The dealer charges a insane amount of money but i really need my car back
Old Oct 24, 2014 | 05:08 PM
exninja's Avatar
What methods did you try to bleed? What are the results? Is there no pressure at the pedal?
Old Oct 25, 2014 | 09:15 AM
mrbelvedere's Avatar
you need to pull vacuum on the system to help pull air out of it
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Silverbullet333
Sep 22, 2015 10:55 AM
